Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-09-2008, 03:18 PM
the last f-100 is starting off with a positive reputation.
Thumbs up 83 f100 turbo 300 6
hello everone this is my 1st time to post, i am puting a t-61 turbo on my 300 6, i just got the turbo in from turbonetics, A/R70,A/R63, I'm useing a vortech carb enclosure with a 600cfm carb useing my stock exhaust manifold until i make a better one,im going to try to install today or trying to see wheres the best place to put it, i will have pics soon ,thank's the last f-100
  #2 (permalink)
Old 04-09-2008, 06:02 PM
well i check out where to put the turbo,looks like the best place would be the driver side of the motor, under the oil filter, i may have to move the oil filter so i can put the turbo a lil higher so it will drain into the oil pan, the only hard time i'm have is trying to hold up the turbo it's almost 30LB's and trying to see where to put it , but i will make some bracket's tomorrow to hold thing's up (any one in central louisiana) c u
  #3 (permalink)
Old 04-09-2008, 10:03 PM
xlman is starting off with a positive reputation.
Pics, pics, pics --------------
__________________
1982 F150 Stepside - 400, 4spd/od,
1967 Mustang - 200, 3spd
  #4 (permalink)
Old 04-10-2008, 07:25 AM
SR_Crewchief is starting off with a positive reputation.
You should have more than enough room on the passenger side below the manifolds for that turbo. Much larger turbos (Holset B1's for example) have been able to fit there.
Consider replacing your log exhaust manifold with EFI manifolds and fab dual j-pipe with a T3 flange(at least I presume that you bought one with a T3 vs the larger T4) . With the turbo in this location you plumbing headaches should be a lot less than running back and forth to both sides of the engine bay.
__________________
1988 F150 std cab LB 4x2 300/4.9l M5OD 3.08's 288,000+ original miles.
  #5 (permalink)
Old 04-10-2008, 07:51 AM
still trying to install pic's don't no if it's me or what can one help me out, i can weld and fab but don't no that much about p c's,,,,thank's
  #6 (permalink)
Old 04-10-2008, 12:29 PM
hello, sr crewchief, thank's for the reply, yes i have a t-3 flange and seen a few turbo's on efi's 300-6's i did not think of the efi exhaust manifold's come to think of it, you may have save me a lot of time and hard work, i would like to stay on the pass side but with the vortech carb enclosure it's kind of in the way but with a lil help from you and other's it may just work out all right, i am still trying to put pic's on here but can only find out how to put them under my user name, if you would send me your email i will send some to you,,,, thank's for your reply and your help,,, i c.u.later,,,,keith
  #7 (permalink)
Old 04-10-2008, 01:14 PM
chrono4's Avatar
The bronco kid
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
send them to me and I'll post them for ya. chrono4211990@yahoo.com
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
STGs MinionsTechnical Advisor
  #8 (permalink)
Old 04-11-2008, 06:53 PM
thelastf100, lots of great guys here to help ya out. can't wait to see how you're coming along. Good luck.
__________________
  #9 (permalink)
Old 04-11-2008, 10:21 PM
turbo
hello ever one, well i know where i'm going to put the turbo, it's will be right on top of the pass/side motor mount just in front of the exhaust outlet, i will come out the exhaust with a 180 U-bend go in between the motor and exhaust outlet along side the freeze out plugs then with a short 90 l-bend with a t3/t4 flange, come to find i have a friend that work's at a muffler shop and i'm going to bring the exhaust/intake manifold to there shop and bend up some peaces of tubing and then i will weld the up myself at my shop, i think i will need to move the alternator up a lil so i will be able to install the air intake to the front of the turbo, i have alot of room out the back of the turbo for the 4" exhaust, i hope by monday i may be on my motor, once the turbo get's installed it's all cake after that,,,,,thank's,,, c u later,,, the last f-100
  #10 (permalink)
Old 04-11-2008, 10:41 PM
Thumbs up the last f-100's turbo 6
Quote:
ok thank's i will send them to your email,,,,keith
  #11 (permalink)
Old 04-11-2008, 11:36 PM
chrono4's Avatar
The bronco kid
Here's what I have:
__________________
--Andrew--
Welding a 9"
  #12 (permalink)
Old 04-11-2008, 11:37 PM
chrono4's Avatar
The bronco kid
pretty sweet start if you ask me. That's what I have planned for mine, only with propane.
__________________
--Andrew--
Welding a 9"
  #13 (permalink)
Old 04-12-2008, 02:41 PM
chrono4's Avatar
The bronco kid
__________________
--Andrew--
Welding a 9"
  #14 (permalink)
Old 04-12-2008, 05:11 PM
thank's chrono4 for posting my pic's, i just wanted it to be seen by other's so it may help someone out, also check out classicinline.com they have alot of ford 6"s, the fastest 6 cyl is a falcon with a 200 6, it has a t-4 turbo, a classic inline new alum-head,alum-manifold, dui distributor it does the 1/4 in the mid 10's has over 450HP and over 500LB of torque, they have all kind's of speed part's for ford 6's most for 170,200,240, but some for the 300, they are now doing a alum-head for the 300 it was going to be out by the end of last year by some one mess up on the plan's so it was held up, when the made the head for the small 6's they give i think 3 or 4 out the gear-heads on the classic inline forum, what luck, when will be my turn. check it out it's all on there,,,,thank's again for posting the pic's,, c u later,,,the last f-100
  #15 (permalink)
Old 04-13-2008, 09:44 PM
I had joined that forum to learn more bout' my 67 mustang 200/6. Really good place.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
