Noob ?'s, Flame suit on.....
Thanks man, with the 2.5" does the front sit alittle higher then the back? I might just do 33's. Notcied in your sing you have the Volant CA and Edge, you like them? I want a loud Intake for my truck, is the Volant? The Edge looks like a nice tuner, you notice any gains? I usually run 93 in my truck just cause it seems to like it more then 87 and seem to get better mpg. I also have a Sunoco around that offers 94, would the Edge help bring out more power on a 94 octane tune?
"2.5" could give you a "nose high" look."
I suppose it could give you a nose up stance since it seems some have had this problem but if you look in my gallery you will see my truck has a big box in the back, its called a dog box, anyway that thing ways about 100lbs and when I have my two GSDs with full equipment it weighs right around 275 lbs. and the truck measured from the top of tire to the bottom of the fender the front is still .25" down.
Anyway what I am getting at is it probably depends on a lot of different variables as to how the leveling kit will effect your truck, type of kit, how good of shape your springs/struts are in, etc.
I would say if you have the money and you really want 35s put the 2.5" kit in and if you go nose up slap in an add a leaf kit in the back and your good to go.
Definitly bro, I am worried cause I'm going to be plowing with my 05 SC next winter. I hope with the added plow weight in the front it wont cause problems with rubbing, etc. Worst case I'll just put the stock tires back on. My goal is to be into a Turb Dez F350 by the end of the summer anyway. But thats only if I have a good work summer and make some money. Hopefully the economy turns around. But I'm definitly gonna play around with my F150 this summer. It SCREAMING for an intake and exhaust. The truck feels so restriced. Still trying to find an Intake. Everyone seems to be running the Volant. I want something loud, LOL. For exhaust I was just gonna bring it to a local exhaust shop and come off the cats 3" into a 40 series Flowmaster and back into duals behind rear tires. Dont like the under bumper look(sorry if someone has that, just personal preferance), so I hope that will be loud. I'll definitly post some pics within the next couple weeks while I'm doing these mods. Have a buddy with a dyno shop too. Might strap her on stock and then with the Intake, Exhaust and Edge. See if theres really a diference.
on
Just because Ford has upgraded firmware does not mean there's a "recall" for it, They issue new firmware to address different areas. If your truck is under warranty, the upgrade (Reflash) will not cost you anything. If not, expect to pay a labor charge. If you are a good customer, they may do it for nothing.
i have a 04 f150 supercrew 5.4 fx4 i had the same BANG noise at the same times you explained i took to the dealership. and had my uncle work on it and he replaced the driveshaft, he said that they had alot of problems with the driveshafts on the supercrews wearing out and would make that real loud bang noise.
I am also wondering about these questions. i want to put a 2" or 2.5" leveling kit on my truck and wondering if 35's are going to work or wat to do. kild1's truck is bad*ss looking i want mine to look like that. Also, this is the first ford ive ever owned. is it going to have enough power to turn the 35's over if i get into mud or anything??
Cool beans...I'll take a 1/2" rake...Stock looks cool too. I guess when I do it, and go with the 33's, it'll be the 2" kit...Probably a 1/2" less stress on the upper ball joints, also.
#28
So the problem is whenever I'm driving under normal conditions, lets say I'm behind some one and they go to turn off so like anyone else would do I press the brake to slow down. As the person turns off obv the truck is at a lower speed with the trans still in a higher gear. When I give it gas to get back up to speed it seems like the tranny hesitates the downshift and when it does downshift theres a loud bang and it feels like my dash is gonna come off. It doesnt happen all the time. Usually getting on and onramp of a highway and the truck downshifts to pick up speed it makes this banging noise. Whenever it downshift from a higher gear it seems to do it. Its really annoying and Fords been no help. SO hopefully someone can help.
Brian
Brian
05-6-21 - 05-10-12 - 06-8-2
I talked with my dealer about the tsb's and they went ahead and reflashed my pcm along with lubing the slip yoke. That only lasted about 4K miles and my problem came back. So this time I went for a ride with the mechanic that was going to fix it and showed him what it was doing. In my case I could make it do it when I would reapply throttle after slowing down from any speed in 3 gear, to speeds between 18-20mph (sometimes a little higher). I would get the clunk as it would shift down. I told him it was worse when merging into traffic sometimes but that is harder to duplicate.
He pulled my drive shaft again but this time he replaced it. So far so good The new drive shaft is aluminium no more rust
I would also like to add that I had an Edge tuner and now I have an Xcal3 with Troyer tunes, both of them seemed to make it do it worse. But not anymore since the drive shaft was replaced.
If you haven't already I would go play with your truck like I did and find the right speed range it does it in and then take the tech for a ride with you. Going up a hill may also make it do it easier, at least it did on mine.
Good luck with it!
Nope
Your plugs I would leave alone They have a 100,000 mile service life. Changing them now would likely result in your pulling the engine for head work that doesn't need to be done at this point (I just broke one off in the head I'm really pissed about it). Took my time and did everything the TSB said. If they are going to break they will break there is no preventing that.
#29
WhiteCrystal, thanks for the help. My truck is doing EXACTLY what your talking about. Going uphill it seems to bang easier when down shifting. Well I'm pissed now because I'm outta my warrenty. What should I do, the Ford Dealerships around here SUCK. No one wants to help. Shut me out as soon as "They couldnt duplicate the problem" on 3 different ocasions I brought it in. Should I just buy a new driveshaft? Probley not cheap. Urgh I have a headach now....
#30
my uncle said that the new driveshaft was gonna cost over 500 dollars when he told me that he was going to have to replace mine. And that was just for the driveshaft, i dont know what they would charge for labor or if that was his cost on it or what sooo... He was saying that they had a lot of problems on the 4 doors with the driveshaft. He was saying that the inner splines were made out of nickle plated steel and then after awhile it would wear off and then get in a bind and when it would free up it would make that loud clunk.
Robert6401
13
02-24-2022 10:23 AM
