Gasget set for overdrive transmission?
Hie everyone
I am in a need for a gasget set for the overdrive transmission in my truck. It's a F100 -56 with a 3-speed manual and overdrive?
At dennis carpenter I have found a gasket set for the 3 speed but I havenīt found any for the overdrive.
The thing is I have a big leakage an output shaft of the overdrive transmission that I have to do something about before I take it out for the summer.
Best rergards Jimmy
Best rergards Jimmy
21C7052A > > replaced by > > C4TZ7052A > > replaced by > > D9BZ7052A .. O/D Output Shaft Seal.
Ford suggested retail price: $17.98 / ftepartsguy.com price: $12.95
There's also a tailshaft bushing (it's pressed in). Over time, it develops burrs and then tears up the seal.
B3TZ7A034A > > replaced by > > B3TZ7A034B .. O/D T/S Bushing.
Ford suggested retail price: $7.66 / ftepartsguy.com price: $5.52.
Yes, you're readin' that right...both parts are still available from FoMoCo.
FTE sponsor: ftepartsguy.com = Ed Olson @ Parr Ford, Bremerton WA.
If you type either p/n into the website, it won't say the parts fit a 1956 F100, because the website only reflects the 1980's and later vehicles.
But they DO fit 1956's. Guar-anteed.
I look up the part numbers, type them into his site, and you can see the result. :-)
You can have one, too.
hipoparts.com sells a CD version / also available on ebay for around 20 euros.
