Ther's no need to weld the tube, just remove it completely. The tube goes down to a fitting on the front of the pass side manifold. Remove the tube from the fitting and remove the fitting from the manifold. The manifold is tapped for 1/4 npt, so put a pipe plug where the fitting is supposed to be.
With the EBP sensor unplugged a code will show up on a scanner but it wont effect the way the truck runs
Blue Mule, welcome to this site, you are the same of the other forum, arent you? Your contributions here will be great, Im sure.
Thanks for the welcome.
I've been here for a few years but haven't posted much.
You've probably seen me on TDS. I used to post over there before it went down the tube.
