1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
HELP ! #13 fuse keeps blowing
Old 04-08-2008, 09:31 PM
waterdawg's Avatar
waterdawg
waterdawg is offline
I have a 2000 F250 V10 and had to replace the battery so i jumped it and drove it to the shop and repalaced it
now a friend of mine noticed i had no brake lights, so i check the fuse and it was blown so i replaced it and it blew within seconds of putting it in. check the bulbs and they all look ok
where would be a good place to start ? and what are some of the things i should be checking
Old 04-08-2008, 09:38 PM
ageel's Avatar
ageel
ageel is offline
I would start at the wires under the rear end above the bumper, they get some abuse from rocks and gravel where the trailer plug connects (if you have one)
Old 04-09-2008, 09:28 AM
BareBones's Avatar
BareBones
BareBones is offline
Also check the sockets. Sometimes they corrode over time and create a short.
Old 04-09-2008, 09:45 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
What's #13 for?
Anything aftermarket added, like stereo equipment or two-way radios that make a big draw, and would be wired to the battery directly? In other words, any wires that used to be connected to the battery that are now just flopping around?
Old 04-09-2008, 10:02 AM
waterdawg's Avatar
waterdawg
the manual says its for Stop Lamps, Center High-mount Stop
Lamp, Trailer Tow Stop Lamp, Speed Control. I dont have any aftermarket items at all
dunwannotrouble
06-17-2018 09:09 PM
jayc3169
03-07-2011 01:39 PM
gritsngumbo
08-20-2007 10:58 PM
ACarbone624
17
08-03-2007 10:09 PM
wycowboy
12-05-2005 07:53 PM
Quick Reply: HELP ! #13 fuse keeps blowing
