Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-08-2008, 08:36 PM
Jarma36 is starting off with a positive reputation.
CB Radio
hey,
i have never done any sort of wiring in a vehicle, havent even installed my own cd deck, i need to install my BC radio in my truck, 95 f250, and was wondering if someone could tell me where i wire the power? its just got the red and black cables.
thanks
  #2 (permalink)
Old 04-09-2008, 02:01 AM
ReAX's Avatar
ReAX is gaining momentum as a positive member of FTE.
The black to goes to a chassis ground, there should be several wires bolted to the metal under the dash, install a ring or U terminal and bolt it with those. The red wire depends on if you want to use the radio with the key off. If yes, you need to find a constant power in the fuse box, or run a wire with a fuse to the battery. Going to the battery may give you slightly less engine noise. If you don't want the radio on with the key off, the radio circuit would be a pretty good choice.
Be sure not to run your coax (RG58/GR8) near any power wires, and use a gromet where it passes through sheet metal. I like to keep my coax about a foot way from any other wires and make a coil of the excess near the antenna.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 04-09-2008, 02:10 AM
ReAX's Avatar
Please, if you don't have any terminals, pick some up. You don't have to use severe service terminals, you don't have to solder and heat shrink them, but don't just strip the wire and wrap it around the bolt.
If your going to the fuse box, scotch locks or taps are an easy way to go, conversely, you can cut off about a 1/2 inch of the insulation, poke an awl through the wire and tie the new wire in, solder it, then wrap in electrical tape. Some will say one is superior to the other, but they both work well.
For the fuse, try to use a fuse holder that holds the same fuse that's in your fuse box. You probably have ATC (full size blade) fuses, this makes it easier to have replacements on hand. With the fuse holder, put a ring/eye or U terminal on one end, and then buttsplice or tie and solder to your wire you have run through the fire wall.
With all wires that pass through sheet metal, put a rubber gromet around them, it protects the wire from chaffing and shorting out.
For the antenna, the solid wire in the middle of the coax gets attached to the antenna lead. On the ball mounts I use, it's the screw in the middle of the main nut. Then the wire mesh around the center conductor needs to go to a ground near the antenna. I usually unlace a couple of inches, put heat shrink and a ring/eye terminal on it.
__________________
-MECP 06/27/08
  #4 (permalink)
Old 04-09-2008, 08:06 PM
thank you very much for your help!
  #5 (permalink)
Old 04-09-2008, 08:29 PM
maverick1701 is starting off with a positive reputation.
I used a fuse tap for my CB, used the "power point" fuse so I have power even if the engines is turned off. I think they run $2 for a box of 7 at napa
__________________
1994.5 F-350 Crew Cab Long-Bed W/7.3 Powerstroke; 317,000 miles and still going strong; 410s; 33in BFG Mud-Terrain 305/70-R16; Manual Trans; Warn hubs; 115gal transfer tank; grill guard; no cats; no muffler; Trail-Boss "Roper Rack"
http://youtube.com/watch?v=BRzhJdmGYNY
http://youtube.com/watch?v=tJjQa-lNDQ0
http://youtube.com/watch?v=rs790NaFS64
  #6 (permalink)
Old 04-09-2008, 08:55 PM
ReAX's Avatar
That's not the tap-a-circuit then Tapa Circuit Dual ATO Fuseholder Wirthco Engineering, Inc.
I'd rather use one of these than the old brass tabs that fit around the fuse. These are a bit more expensive, probably 1.50 each.
__________________
-MECP 06/27/08
  #7 (permalink)
Old 04-09-2008, 10:35 PM
correct... the fuse taps are the pieces that fit around the fuse
__________________
  #8 (permalink)
Old 04-09-2008, 10:45 PM
ReAX's Avatar
Just as a side note, on the mini blade fuses, you can use a U wire terminal, just cut one of the ears off, and it will slide down next to the fuse. You can probably get away with it on ATC fuses too, but I haven't tried it.
__________________
-MECP 06/27/08
  #9 (permalink)
Old 04-10-2008, 12:06 AM
WilliesSD250's Avatar
Feed 'Em Steel
WilliesSD250 is starting off with a positive reputation.
Exclamation
Also remember NEVER key up your radio without an antenna installed. This includes antennas like the Wilson and K40 with the removable (quick disconnect) antenna. Keying up without an antenna installed will blow your finals.
__________________
Due to the weak Chinook Salmon runs and the HIGH fuel prices, the Alaska Department of Fish and Game has closed TOURIST SEASON for the remainder of the year. If you should see a tourist you should release them to either YT or BC, Canada
  #10 (permalink)
Old 04-10-2008, 09:02 PM
oh thanks for the tip! wouldnt a known that
  #11 (permalink)
Old 04-18-2008, 03:12 PM
Gage2502 is starting off with a positive reputation.
How do you know if you have blowen yout CB?
~Gage~
__________________
2005 Ford SuperDuty XLT SuperCab V10 4x4 FX4 Shortbed
2000 Ford Expedition XLT Sport 4x4 5.4L
  #12 (permalink)
Old 04-18-2008, 05:37 PM
I have wondered the same thing...I have been using my CB as a PA without my antenna (it should be comming in monday if ups isn't late) and I am wondering if I fried anything
__________________
  #13 (permalink)
Old 04-18-2008, 05:46 PM
ReAX's Avatar
It's hard to tell until you have it hooked up. Once you have it hooked up, go to your local trucker's channel (typically 19) and ask for a radio check and location. I think CB legal limit is 4watts, so you shouldn't talk much over a couple miles depending on interference.
The best thing to do, is put an SWR meter on it and tune your antenna. If your SWR doesn't move when you key up, your radio is shot. Conversely, I had a Galaxy DX75 blow smoke on me once.
__________________
-MECP 06/27/08
  #14 (permalink)
Old 04-23-2008, 11:42 PM
big poppa pump's Avatar
Got milk, NO, diesel
big poppa pump has a good reputation on FTE.big poppa pump has a good reputation on FTE.big poppa pump has a good reputation on FTE.
Wow, you don't here about galaxy radio,s frying like that.
__________________
Mike 2003 f-250 XLT Superduty CC 7.3 SRW, 156 WB, auto 4x4 373 gears S-B cold air intake w snorkel, WW, superchips programmer 60,90,110,foil delete,mbrp 4 inch ss T409 cool duals, stock 16s with 285 Yoko,s A-T, Bilsteins, Zoodad mod, ARE custom cap, Running lights, Cobra 29 cb peaked and tuned with dual firesticks. PAA MEMBER 26#
  #15 (permalink)
Old 04-23-2008, 11:45 PM
good news.. my radio isnt fried...my cobra is still running strong
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
