The Village Idiot met Me Today
on
1 Post
So all you youngsters who want to drive low little fastback Hondas with fat mufflers, talking chit on da cell phone and flippin everyone off as you weave in and out of traffic......
Prepare yourself! Because that train sound you just heard behind you (that made you crap on the seat because your pants are too low) came from these!
[/IMG]
...and THIS IS coming at you in the rear view mirror - fast!
[/IMG]
Luckily for him, cop got him before I did.
Moral of the story, don't chop 3500 pounds of solid steel and channel iron if you are driving a reconverted Coke can, stupid.
(OK, I'm all better now)
[/IMG]
[/IMG]
Dan,
Tear 'em up!!!! It sure is tempting to bounce those guys off the fender isn't it.
Although I must say it is kinda fun to see the look on their face when the old multi-colored piece of s**t truck downshifts, smokes the tires, and screams past them.
Heck, I don't even need to put one of those coffee can resonators on my trucks tailpipes...lol
Bobby
Bobby
Dan, that is some very funny stuff. I have also thought about putting some of those on my truck. When I owned a bike shop down in Texas, I 'll bet I have installed about 300 of those things on Road Kings and touring bikes. They are loud, and they are just a two trumpet horn. I bet that thing screams.
Received 1,353 Likes
on
on
1 Post
Hi Josh,
All the bullets have tabs that bolt right to the center bar. On this one, I picked up two extra bullets (and you have to be sure and get a left and a right) and drilled the four (two each - top and bottom) to mount them. Then very carefully started grinding off the bottoms of the teeth. They actually sit about 1/16 of an inch up off the lower valance upper surface (confused?). The reason I did that is because I designed it so I could quick swap it out with a stock three tooth. In building both Grilles, I brazed stainless mounting bolts onto the backs of the headlight cans and mounted the parking lights on the headlight can instead of on the valance. I wired them exactly the same and used a trailor plug to connect the headlight and parking light wires on each. So, all I have to do is remove the wing nuts (two wing nuts one nylon lock nut for safety), unplug the trailor plug and gently drop the grill off the front of the truck with the tilt hood up about half way. Then I slip the other one on, tighten the wing nuts plug it in and I'm back to stock! I love my toys and mods, but I'm putting them in without cutting or damaging the original metal so I can return it to 100% stock in a snap if I ever decide to (or it's next owner decides after I'm DEAD). That's why the clock is in the ash tray too. Got two ash trays!
Here's a pic of the 3 bullet grille - just finished it a couple weeks ago.
[/IMG]
Here's a pic of a truck with a chrome 5 tooth (mine will be white)
[/IMG]
AND one with SEVEN TEETH! This one is cool but a bit much for me - you are getting close to a DeSoto Style grille with that.
[/IMG]
I'll be taking lots of pictures and writing up little tech pamphlets galleries on all my mods. I'll put th eword out when I get some finished!
Again thanks for the kind words!
[/IMG]
[/IMG]
[/IMG]
Unfortunately, that's one of the downsides of living in San Diego......
The lowered crap-wagons with the coffee-can exhaust tip and shaved-head vertically-challenged idiots are thick out here.
On the bright side.... Instead of living in La Mesa... it could be worse.... you could be in Mira Mesa.......
