Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-08-2008, 02:02 PM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
Okay I'm stumped...
I raced 2300 for years bought junk cars and got the 2300 to run but this dang mustang will not run......here the low down
86 mustang 2.3 with a t-5 now (clutch was out on the 4 speed so I swapped a 5 speed in) I have blue fire to the plugs rechecked the firing order... getting fuel... compresion is 100 90 130 130 I know 1 and 2 are low but should hit... I can't get a backfire or a hit out of it even took the valve cover off and all valves are working up and down... any ideals got fire copression and fuel this thing is driving me crazy....
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
  #2 (permalink)
Old 04-08-2008, 08:51 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
Are you sure the firing order isn't 180º out?
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #3 (permalink)
Old 04-09-2008, 10:27 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Sounds like a timing problem, either ignition as Jared suggested or valve timing. Check to make sure the timing marks all line up on the cam and crank, then check the ignition timing....
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #4 (permalink)
Old 04-09-2008, 06:59 PM
worse part the car was only parked 2 years ago... anyway update... decided to take plugs out put some gas on them then lit them on fire (to burn the crud out) installed them and it would hit almost a back fire (acted like more than just 180 out... so I tried to rewire it 180 out nothing no hit tried moving the plug wires 1 off nothing... I think I'll try a new set of plugs....
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
