Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-08-2008, 01:02 PM
460429_freak's Avatar
460429_freak is starting off with a positive reputation.
Okay I'm stumped...
I raced 2300 for years bought junk cars and got the 2300 to run but this dang mustang will not run......here the low down
86 mustang 2.3 with a t-5 now (clutch was out on the 4 speed so I swapped a 5 speed in) I have blue fire to the plugs rechecked the firing order... getting fuel... compresion is 100 90 130 130 I know 1 and 2 are low but should hit... I can't get a backfire or a hit out of it even took the valve cover off and all valves are working up and down... any ideals got fire copression and fuel this thing is driving me crazy....
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-08-2008, 07:51 PM
Ford_Six's Avatar
Ford_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to behold
Are you sure the firing order isn't 180º out?
__________________
Jared
Quote:
Originally Posted by Tadao Ando
"If you give people nothingness, they can ponder what can be achieved from that nothingness."
FTE Guidelines
  #3 (permalink)
Old 04-09-2008, 09:27 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Sounds like a timing problem, either ignition as Jared suggested or valve timing. Check to make sure the timing marks all line up on the cam and crank, then check the ignition timing....
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
  #4 (permalink)
Old 04-09-2008, 05:59 PM
worse part the car was only parked 2 years ago... anyway update... decided to take plugs out put some gas on them then lit them on fire (to burn the crud out) installed them and it would hit almost a back fire (acted like more than just 180 out... so I tried to rewire it 180 out nothing no hit tried moving the plug wires 1 off nothing... I think I'll try a new set of plugs....
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
