Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-08-2008, 10:59 AM
Aero-fan's Avatar
Aero-fan is starting off with a positive reputation.
Power steering fluid flush?
Seems like a lot of people complain of their power steering pumps/racks going up on aerostars. I hear mine whining too, not necessarily in a bad way, but it made me think there might be value to flushing out the 11 year old fluid. Anyone else do this? Sound like a good idea? I was thinking I could take a turkey baster and suck out most of the old fluid out of the filler and then drain the rest out of the various lines connecting to the rack (manually turning the front wheels all the way in both directions to help pump out the old stuff trapped in the cylinders). Then tighten every thing up and refill with a good synthetic. What do you guys think? Anyone else already done this? Never heard of anyone flushing PS fluid so not sure if it's a dumb idea or not.
__________________
1997 Aerostar Extended 3.0 2WD, 28K miles
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-08-2008, 11:05 AM
VanGo's Avatar
VanGo is starting off with a positive reputation.
That's what I did. I also added an inline filter on the return side. Probably too late in life but if anything is breaking down it will be trapped.
Magnefine
__________________
----Justin----
  #3 (permalink)
Old 04-08-2008, 11:13 AM
Aero-fan's Avatar
Thanks vango. How do you install an inline filter on the return side? Simply cut the line and install one or does it involve fittings etc? What type of filter did you use?
__________________
  #4 (permalink)
Old 04-08-2008, 11:21 AM
VanGo's Avatar
Just cut the return line. I used one of their standard transmission filters
Magnefine--Magnefine Filter Installation Instructions
__________________
----Justin----
  #5 (permalink)
Old 04-08-2008, 11:35 AM
Aero-fan's Avatar
Cool, great idea vango! Thanks for the link, I'll probably put one of those in too. I'm assuming the 3/8" size is what's needed?
__________________
  #6 (permalink)
Old 04-08-2008, 11:53 AM
VanGo's Avatar
I can't take credit for it. It was someone on this forum though.
I'm pretty sure it's 3/8"
__________________
----Justin----
  #7 (permalink)
Old 04-08-2008, 12:01 PM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
search the aero forum for ps system flush.
use a quality synthetic ATF Mercon such as Mobil1
put front end on jack stands
pull the ps return line off off reservoir, into drain, run engine and turn steering wheel back and forth while adding ATF. turn engine on and off to pump out and refill.
repeat until clean ATF comes out.
  #8 (permalink)
Old 04-08-2008, 02:10 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
I think I'll get one of those as well. I need to change my fluid again, it has gotten water in it. I'll go with a good synthetic ATF. The source of the water getting in has been resolved too.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #9 (permalink)
Old 04-08-2008, 02:36 PM
VanGo's Avatar
Read about them and decide how many to order for your situation. They are consumable so you may save some on shipping.
__________________
----Justin----
  #10 (permalink)
Old 04-08-2008, 03:01 PM
Aeroman59's Avatar
Aeroman59 is starting off with a positive reputation.
Quote:
If you do decide to use a filter, I would change it about every 1 or 2 years since a blocked filter is worse than dirty fluid! Make a note on the filter.
Aeroman.
P.S. The whine you can hear is normal for a Ford Aerostar pump. It is related to engine speed & pump load, it goes away when engine revs increase above about 1.5-2k Revs.
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 292,000 kms & going strong !
  #11 (permalink)
Old 04-08-2008, 03:25 PM
VanGo's Avatar
Quote:
I asked the vendor about this before I ordered mine. They have a bypass so the won't block up. Still, you need to change them.
__________________
----Justin----
  #12 (permalink)
Old 04-08-2008, 04:29 PM
96_4wdr's Avatar
many auto parts stores and all quality auto tranny shops carry these in line filters.
Filtran and Microfine are 2 of the most avail.
  #13 (permalink)
Old 04-08-2008, 08:06 PM
Aero-fan's Avatar
Thanks everyone, this site is fantastic. Tons of great info that makes me feel confident I can keep my cherrystar going for a zilliion miles. So I should use ATF, and Mercon V type synthetic would be best? How much will I need for a full flush/replacement? Also when I go to cut the return line and insert the filter, is the line steel reinforced or is it just nylon reinforced so I can cut it pretty easily with a razor?
__________________
  #14 (permalink)
Old 04-09-2008, 07:31 PM
93nighthawk's Avatar
93nighthawk is starting off with a positive reputation.
I believe the return line is nylon re-enforced, but I could be wrong.
As for how much, it usually takes 1-1/2 to 2qts of fluid. MerconV would be fine sense it is already fully synthetic.
__________________
'96 Ford Contour 2.0 I4 MTX 77k mi- Rear Ended 12/22/07
'97 Ford Aerostar AWD 4.0L v6 AT 81kmi
'97 Chevy Lumina 3.1 v6 ATX 135k mi Parents old beater, temp vehicle
Future: 2009/10 Taurus SHO, Loaded
My Car Domain
The Possum Aero-Van!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
