Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-07-2008, 11:09 PM
danlyst13 danlyst13 is offline
Garage is empty, add now
danlyst13 is starting off with a positive reputation.
trailer brake/turn signals light not working
I have a 2004 f-350 psd. i tow a few trailers with it and of all of them the running lights work just fine, however the turn signal and brake lights arent getting any juice. I checked the fuses under the dash and i checked to see if all the wires were in one piece and all seemed fine. ill take any advice i can take. Thanks
  #2 (permalink)
Old 04-08-2008, 12:16 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
This info is from a 2003 superduty diagram, so I hope it's the same.
The left and right turn come from fuse #6, 20 amp in the underdash fuse box. The power leads to a aux relay box #5, which is located under the hood, on the driver's side near the firewall.
The running lights for the trailer come from fuse #38 in the underdash fuse box, go to a trailer tow relay parking lamps, which is built into the fuse box and you can't get to it, and then leaves to go to the rear on a brown/white wire.
It's unusual that both the turn/brake and the parking lights are both out. I would make sure everything is plugged in at the rear.
__________________
Dave F
1989 F250 XLT Diesel
Tags
1997, 2003, 2011, brake, brakes, electric, f150, f250, f350, lights, signal, signals, trailer, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
