Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #1 (permalink)
Old 04-07-2008, 08:58 PM
Dustin_86 Dustin_86 is offline
Garage is empty, add now
Dustin_86 is starting off with a positive reputation.
Question truck pulls
I went to the truck pulls with a few buds. One had a 97 PSD 4x4 5spd- he did decent. The other buddy has a 74 int 1 ton pickup with a CHEVY 292 6 and granny 4spd. He finished mid track, this kind of inspires me to pull my 78 f250 300. How would they compare my 300 4spd to his 292 4spd. Would I finish mid track if he did??
Dustin
__________________
1978 F250 2wd RC,LWB,300 I6
NP 435 3.73 trak loc HD 460 V8 coil springs
At least the Chow lets you know it is unstable, she just left cheated and called back crying with her appologies.
Reasons To get a dog over a women
  #2 (permalink)
Old 04-10-2008, 11:14 AM
DirtStripHero's Avatar
DirtStripHero DirtStripHero is offline
DirtStripHero is starting off with a positive reputation.
There are a lot of variables there. 4wd or 2wd? What are both of your gear ratios? What kind of tires do you bot have? It depends on sled and how much weight they put on it initially. I have a 1980 with a 460 in it that is basically bone stock and depending on the sled I have finished everywhere from 290ft to 150ft. If ratios and tires are similar then I would expect you to finish around where he did, you would probably have a slight advantage.
  #3 (permalink)
Old 04-10-2008, 11:15 AM
Sorry I see now that you have a 2wd and a 3.73 rear end. I guess I need to read you signature next time.
  #4 (permalink)
Old 04-14-2008, 08:24 AM
I have WAY better tires than he does. I have 3.73's/Np435, he has ummmm it turns 3k rpm at 60mph with 29'' tires ans a chevy sm465 trans. the wierd part is he said he "ran out" of power even in low gear in which he pulled about 148'' it pulled him down till he stalled. I wouldn't think anything would pull my 78 300/np435 down like that in low she is a beast. He NEVER had a tracton issue eather, he never spun. uuuuu ooohhh
We are both 2wd the sled was 32,000lbs, he took off with it easy
__________________
  #5 (permalink)
Old 04-14-2008, 04:38 PM
Ya if he is turning 3k at 60mph then he has a pretty low ratio. But the NP435 is an amazing tranny with a nice creeper granny gear. You should probably take him especially if you have better tires. Traction is huge and most people don't realize it. The weight of the sled isn't really anything at the start ofthe pull, but I find it interesting that it bogged down without spinning the tires. That is usually the sign of a well-worn engine with a poor ignition coil and plug wires. If your truck has been keep in descent condition I think you should come out on top.
__________________
Michael
"If it has **** or wheels, It will give you trouble."
2000 F-150 4.2L, 5spd, 3.55, 4x4
1984 F-350 6.9L 2wd, T-19
1980 F-250 460, c6, 4x4, pulling truck
  #6 (permalink)
Old 04-14-2008, 06:02 PM
I rebuilt the motor and have taken very good care of it wix filters/moble 1 oil sense then. i think it is really strong. Fires right up, idels smooth. no oil consumption in the 6 month oci's- aboout 1500miles between changes
__________________
  #7 (permalink)
Old 04-14-2008, 06:23 PM
brh1969 brh1969 is offline
brh1969 is starting off with a positive reputation.
I wouldnt be too quick to judge your buddy yet.Its a whole different ball game when you hook to a sled.Theres just to many variables to say he just plain powered out.Ive seen 1000 hp 4x4 Pro Stocks "power out".A guy i used to pull with actually set his truck up to "power out".His theory was he wanted the engine to almost stall when his tires quit turning,when his momentum stopped and he was running a 990 hp BBF,2WD mod.
1500 miles on Mobil 1?That gets a little pricey dont it?
__________________
1977 F250 Super Cab Trailer Special 460 C-6
2002 F250 PSD
  #8 (permalink)
Old 04-14-2008, 07:20 PM
every 6 months, can I take it longer a year maybe?
__________________
  #9 (permalink)
Old 04-14-2008, 07:28 PM
BRH I agree completely with you about the Pro Stock trucks. Once you build them up, it is a whole new ballgame. But from the way that hae has talked, I don't think his buddy's truck is souped up too much. From what I have seen on stock trucks they either seem bogged down from the start or they go till they spin the wheels.
And ya Dustin I would go the full 3,000 miles. Unless you let your truck sit a lot, then you really don't need to pay attention to the time very much. If you change it once a year at 3,000 miles you will be fine, especially with a rebuilt, well maintained motor.
__________________
Michael
  #10 (permalink)
Old 04-14-2008, 07:43 PM
I know what you are sayin Dirtstrip.I realize we are talkin about stock trucks.What im saying is just because he "powered out" doesnt mean he has no power.Could be he was gettin a good bite.Sometimes on a hard track slicker tires are better.Ive been on tracks where we wouldve done better with slicks,no kiddin.Im just sayin watch that 292 Chevy before you talk to much they can run.Everybody can pull the hell out of a sled....until they hook on to it.
__________________
2002 F250 PSD
  #11 (permalink)
Old 04-15-2008, 04:02 AM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
I have always said the three best motors Ford ever put in to a pickup truck were the 300 six.460 an 390 FE motor. If you had either off them in a pulling truck you would do alright. Put that truck in granny low get the RPMs up there an take off. I myself enjoy watching the 2wds pull. With the 4wds you have constantly worry about the front end. Enough weight or to much. Air pressure an such. With 2wds much less problems. I think your truck will do great. So get her ready for the next pull. Post up an tell us how you do. I think you might out do your buddy with his truck. Since you say you have better tires. My dream pull truck would be a 2wd 79 250 with a 460 in it. I would do some mods such as cam, headers. high performance carb. The whole 9 yards. Those 460s are pulling beasts like the 300 six. Got that great torque down low an like the 300 six an built like a tank. With reg maintenance them motors will run forever even if you abuse them an pull the heck out off them. Thats a Ford for you they run forever an a day with out breaking the bank. Good luck now get that truck to the next pull.
__________________
BUILT FORD TOUGH
Tags
460, 4x4, bbf, cam, ford, gear, good, pull, pullers, pulling, pulls, run, sled, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
