Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 401, 477, and 534 SD Engines
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-07-2008, 08:38 PM
less less is offline
less is gaining momentum as a positive member of FTE.
409 or 534 which was better truck engine ?
I could be wrong, but my understanding was that the Chev 409 was used in medium and heavy duty Chev trucks and the 534 was used in Ford MDT/HDT.
I'm assuming that the Ford 534 might of been the better truck engine, due to it's significantly greater displacement which would give more torque than the 409, I'm guessing.
I'm also thinking that as the Ford was a purpose built truck engine and the Chevy 409 did double duty as a car and truck engine, that Ford would of had a chance to make sure that the 534 design could be pure truck.
But not having had any experience with either engine, I leave it to those, that know.
  #2 (permalink)
Old 04-09-2008, 03:39 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
The 401-477-534 engines were truck only. Very large and heavy.
The 348/409 motors were truck/car engines. The 409 is very oversquare, in fact one of, if not the biggest bore/shortest stroke motor of it's time.
(4.3125 x 3.5)
This has almost all car and drag race info on the 348/409. Chev had a good thing going there for a while:
348 And 409 W-Engines - Chevy's First Big-Blocks - Super Chevy Magazine
Spec sheet here, 348 220 horse @ 4400, 325 torque @ 2600, 409 252 @4000, and 390 lb/ft @ 2400.
348/409 engine specifications
Shows this for series 80 and 60 trucks. The 60 is roughly equal to the F600 of the time, I think. Not sure about the 80, maybe the F700 or so.
quote from another posting, stay tuned:
Louisville Joe ******** type=text/javascript> vbmenu_register("postmenu_3306661", true); *********>
I just found my 1962 Motor's truck manual. The 534 is listed as having 270 h.p. @ 3200 r.p.m., and 481 ft. lbs. @ 1900. The GMC 702 V-12 is listed at 275 h.p. @ 2400 r.p.m., and 630 ft. lbs. @ 1600 r.p.m.. The International 549 V-8 is listed at 256 h.p. @ 3200 r.p.m., and 505 ft. lbs. @ 2000 r.p.m.. Kind of fun looking at the spec.'s of those old monsters!
The above from:
http://www.ford-trucks.com/forums/44...yone-else.html
So the 409 was probably in line with the 401 power wise.
Anyway, happy reading....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
