Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-07-2008, 08:15 PM
Warfarin is starting off with a positive reputation.
Rear Limited Slip
ok I bought a 99 Expedition in January 2008 and everything was fine with it. I took it on a 500 mile trip and the limited slip overheated (I guess) and would not release. After sitting for about 4 hours it worked fine. On the way home it did it again but as I got closer to home and the outside temp droped it started working fine. Any Ideas?
  #2 (permalink)
Old 04-07-2008, 08:30 PM
pitrow is starting off with a positive reputation.
Sounds like it's time for a rearend fluid change. At the very least check the fluid level, but if you haven't changed it since you bought it, it'd be good insurance to change the fluid to make sure you have the right stuff in there, and to make sure it has the friction modifier in there that the limited slip needs.
__________________
Mike
99 Eddie Bauer Expedition
5.4L, AWD, 3.73 LS Rear, Air Suspension
2000 Ranger
  #3 (permalink)
Old 04-07-2008, 08:35 PM
That's what I was thinking but wasn't 100% sure. Also is Ford the only place to get the friction Modifier?
  #4 (permalink)
Old 04-07-2008, 08:46 PM
well you can get friction modifier just about any parts stores, but most people on here recommend you stick with the ford stuff.
__________________
Mike
2000 Ranger
  #5 (permalink)
Old 04-07-2008, 10:57 PM
thanks!! I appreciate it
  #6 (permalink)
Old 05-15-2008, 11:46 PM
thanks I replaced the gear oil and friction modifier and it works fine now.
  #7 (permalink)
Old 05-16-2008, 01:10 AM
alloro is starting off with a positive reputation.
Was the fluid level low?
  #8 (permalink)
Old 05-16-2008, 09:59 AM
Ya know I didn't even check it. I just poped the cover and drained it into a drain barrel. I figured it had never been changed and at 140K it needed it regardless.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
