DIY Coolant Filter?
  #76
Old 10-18-2009, 10:08 AM
Calkidd's Avatar
Calkidd
Calkidd is offline
OK, I am about to pull my hair out. This is probably the one and only in depth how to on a DIY Coolant Filter thread I have found. However, there is mention about pictures, but I don't see any and they appear to be broken links.
The only question I have is where do you tie in for the inlet to the filter and visa versa the outlet?
  #77
Old 10-18-2009, 11:09 AM
mickpowell1967's Avatar
mickpowell1967
mickpowell1967 is offline
how do you roaut your coolant lines
  #78
Old 10-18-2009, 11:21 AM
janton01's Avatar
janton01
janton01 is offline
Did mine about 3 months ago using the NAPA parts and valves from the local plumbing store. Around $65 or so. I mounted the filter housing on the inside of the frame roughly under the pax seat. I do not do any off roading so not a factor. Easy place to put it and does not crowd the engine comp. I have the 6.0 so taped the line from the engine block to the heater and returned via the small line from the radiator to the degas. One thing that I did add was a clear glass marine fuel inline filter to the return line. It came from West Marine for about $12 or so. Took the filter element out and mounted it in that return line to the de gas bottle. Now you can see the fluid coming from the filter whenever you open the hood. Fluid now a clear golden color. No leaks and easy under truck access to change filters. There are two ball valves at the filter to stop flow for filter change. No more clogging of the oil cooler. Had to replace that and egr due to the oil cooler being plugged with casting sand. $2500 with parts and labor.
The following users liked this post:
AL`
  #79
Old 10-18-2009, 01:37 PM
slowmans's Avatar
slowmans
slowmans is offline
I have a few photos in my gallery, mine is homemade.
  #80
Old 10-18-2009, 02:06 PM
Sark's Avatar
Sark
Sark is offline
Thumbs up
Take a look at these instructions:
http://www.dfuser.com/Install%20Guid...filter_kit.pdf
This tells you how to install a system.
Good Luck!
  #81
Old 04-07-2010, 03:38 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
Going to resurrect the thread again, but an dealer that tells you a cooler will void your warranty is full of it. Research the Magnasun-Moss act, in order for a manufacturer to void a warranty due to aftermarket parts, they have to be able to prove that the failure was directly related to the part installed. Example: A truck with a coolant filter rolls into the dealership with a leaking transmission. The dealership cannot viod the warranty. Another truck with a coolant filter rolls into the dealership with warped heads due to a lack of coolant because the system leaked out the filter system, then they have evey right to void the warranty. This is one of the reasons that aftermarket Mustang builders such as Roush and Saleen can add superchargers and such to their cars and yet still comply within the warranty standards. The vehicle is covered under warranty by Ford, the aftermarket parts are covered by the companies that make the parts for Roush and Saleen. Hope this helps.
  #82
Old 05-05-2010, 04:54 PM
owenkicker's Avatar
owenkicker
owenkicker is offline
can anybody tell me what size the hearter hose that you need to hook into is
i found a Multi-Barbed Tube Fitting Reducing Tee for 1/2" X 3/8" X 1/2" brass for $13.50 and a Single-Barbed Tube Fitting Reducing Tee for 5/8" X 3/8" X 5/8" $50.53 stainless i hoping that the 1/2" by 3/8" will work
__________________
  #83
Old 05-05-2010, 05:05 PM
03-6L-X's Avatar
03-6L-X
03-6L-X is offline
__________________
Just measure the heater hose on the passenger side of the rig.
I just went with the Dieselsite setup because I did not want to chase all over the countryside getting parts.
  #84
Old 05-10-2010, 08:46 AM
skyoung's Avatar
skyoung
skyoung is offline
coolant filter
Originally Posted by ozx3+1
Dang! It's purdy too! Nice work!
I like your coolant filter bracket so much I am in the process of doing one myself, just about finished. Could you show me where you connected your high pressure and low pressure lines on the engine.
I discovered I had the filter bracket from a previous truck I wanted to install it into so I was lucky.
Steve Young
skyoung4u@comcast.net
2004 6.0 super cab, short bed
  #85
Old 05-30-2010, 06:37 PM
05whitef250's Avatar
05whitef250
05whitef250 is offline
Got a couple of pictures of mine if it will help anybody...
Picture of the bracket...its actually made of a2 tool steel so its kinda overkill, but its all i had. Little tricky to weld with the little 110 flux core machine i used but its stuck pretty well.
Valves are temporary...kinda large but they work.
Good shot of the welds i mentioned above
I ran the supply side around the intercooler pipe because i was worried about it rubbing and getting hot...i think im going to get some black exhaust wrap and wrap it up soon and hopefully shorten up the hose a bit.
  #86
Old 11-23-2011, 07:31 PM
Ranger375's Avatar
Ranger375
Ranger375 is offline
Just finished my DIY coolant filter install. Well everything but the base which is suppose to be ready to be picked up at Napa Monday. It was pretty easy. Got the Tees at home depo. They are the perfect size for the existing hoses but were pretty tight in the 3/8 hose I bought at Napa. Got everything including the ball valves from grainger for $74. Not Bad. Hit me up if you have any questions.
  #87
Old 11-23-2011, 08:48 PM
Boo_Daddy's Avatar
Boo_Daddy
Boo_Daddy is offline
Hey Ranger,
How did you do your mount?
  #88
Old 11-24-2011, 07:44 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,371 Likes on 2,076 Posts
Nice Do-It-Yourself guys... If you have a little time and a NAPA dealer close, that is all you need.
  #89
Old 11-25-2011, 09:58 PM
Ranger375's Avatar
Ranger375
Boo Daddy. I got a peace of 2" wide 3/16" thick steel from Home Depot and then heated it up with oxy acetylene and bent it to form. I havent installed it yet cause my base is gonna be at Napa until Monday. But when I do i will post a pic.
  #90
Old 11-25-2011, 10:38 PM
run6.0run's Avatar
run6.0run
run6.0run is offline
I only read the 1st and 3rd page but the tool talked about on the first page that is designed to eliminate air pockets is the radkitplus from snap on. I got one off ebay from a pawn shop out east and it is awesome. I do not pour anything into my degas bottle. the tool vacuums down the system and by turning a valve it siphons the coolant in. I also used it to purge air from the steering system.
Quick Reply: DIY Coolant Filter?
