any way to unlock doors without a key? - Ford Truck Enthusiasts Forums
Old 04-07-2008, 07:30 PM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
ok,I pulled the bonehead move of the weak for me,and it's only mionday!! I locked my keys in my truck and I don't have a spare.Truck is a 95 f150 extended cab. Is there any way to unlock it without calling a locksmith? I don't have any of the tools of the trade,slim jim,etc. Lock smith is $60,cheaper than breaking a window I am thinking. thanks,and while you are laughing at me,give me some advice!!
Old 04-07-2008, 07:44 PM
Boz86's Avatar
Boz86 Boz86 is offline
Boz86 is starting off with a positive reputation.
for next time
This won't help you now, but I have the original plastic key cut-out in my wallet for my 92.
Sorry I can't help more.
Old 04-07-2008, 07:49 PM
bad96's Avatar
bad96 bad96 is offline
bad96 is starting off with a positive reputation.
usually the cops have slim jims and can help with no outta pocket expense
Old 04-07-2008, 07:50 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
if ya got the vent window-get some stiff wire and make a hook to flip the handle on it -you also need a flat piece to pull in on the little lock-if you don't you need a slim jim
Old 04-07-2008, 07:52 PM
jr32560's Avatar
Quote:
here in southern Md the cops won't help anymore? I'm getting more and more calls late night because of it
Old 04-07-2008, 08:27 PM
daveshomeservice daveshomeservice is offline
daveshomeservice is starting off with a positive reputation.
standing at drivers door, pry top right corner of door frame w/ large flatead screwdriver.
(gently) straighten a coat hanger, slide thru door gasket and push door lock button.
Does it have a sliding rear window? also good entry point if no power locks.
be patient and good luck
Old 04-07-2008, 08:34 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
borrow some ones aaa card.
Old 04-07-2008, 09:03 PM
well,I needed the truck and didn't have time to mess with it so I just called the locksmith. 2 minutes later I was in. Anybody ever had a problem with the power locks locking themselves? I did not go anywhere near the lock button when I put the keys in the truck. Just wondering if the lock button might be getting "soft" and activating when I shut the door or something?
Old 04-07-2008, 09:43 PM
quicklook2's Avatar
never met a vehicle i could not open.
glad you got in.
Old 04-07-2008, 09:53 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Bend up and shove a metal coat hanger through the edge of the door gasket, between the gasket and the body. Wiggle around and pull the button up.
Old 04-08-2008, 01:13 AM
gweeds's Avatar
gweeds gweeds is offline
gweeds is gaining momentum as a positive member of FTE.
Prying open the door is a good option, but beware. I did it one too many times on my nissan hardbody ( I know, not a good example, but its a tough little guy!) and it perminantly bent the door and now I have a really terrible air leak...
Old 04-08-2008, 03:42 PM
dan91ford150 dan91ford150 is offline
dan91ford150 is starting off with a positive reputation.
Here is what I do: I have a door key electrical taped to a wire harness under the truck (your choice) after road grime gets on it, you can't even tell it is there...
I got tired of the magnet box style, falling off or just screaming "steal me" to someone looking underneath my truck.
The electrical tape does not fall off, and hides a key well...IMHO
Old 04-08-2008, 04:23 PM
Gerber54 Gerber54 is offline
Gerber54 is starting off with a positive reputation.
keep a spare in your wallet
Old 04-08-2008, 04:57 PM
flareside_thunder flareside_thunder is offline
flareside_thunder is starting off with a positive reputation.
Quote:
x2.........
JR
Old 04-08-2008, 05:56 PM
forddorf forddorf is offline
forddorf is starting off with a positive reputation.
For anyone with this problem A BBQ burger flipper will work if its flat. Bust off the wood handles and stick it between glass and weather strip just about where the key is and push down on the linkage inside. Its only down as far as lock or about and between the key hole and back side of door. might take you a min. to find it. And you can also use stiff wire and go in the door gap and pull the clip out of the door that holds the lock cylinder in the door. And then turn the lock cylinder itself.(not EZ but better then pry`n your door with anything) It can be done. Make a key out of old credit card like guy with 92 has and myself that came with truck. Or a rock always works. Oh yeah you say elect. door locks Do they lock with KOER on 95? I know some cars and trucks don`t you have to be in seat. The cops will help If there cops for wanting to help people and not because they want CONTROL of people! If you look like a meth tweak hide or your going to Jail LOL
My 1998 F150 is nervous. It panics whenever I get in it! BRONC-OH 1997 - 2003 F150 8 04-03-2016 03:01 PM
Is there a way to lock keyless fob IN the truck? speedsauto 2015+ F150 10 09-18-2015 12:08 PM
My 1996 F350's doors won't unlock? Any way to manually open a door? CountryGirl3294 1994.5 - 1997 7.3L Power Stroke Diesel 37 11-29-2011 04:47 PM
02 f250 7.3 auto only cranks after unlocking with remote randymacbc 1999 - 2003 7.3L Power Stroke Diesel 3 05-26-2011 08:59 AM
Auto Re-lock? geodude 6.7L Power Stroke Diesel 16 11-23-2010 04:51 PM
Tags
1997, 350, coat, door, f150, ford, hanger, jim, key, keys, rear, slim, truck, unlock, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
