Automotive Calculators
Received 1,353 Likes
on
Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
This link is for:
• Displacement
» Cylinder Volume, Piston Displacement, Stroke, Bore
• Compression Ratio
» Compression Ratio, Chamber Volume, Displacement Ratio, Amount to Mill
• Piston Speed
» Mean Piston Speed, RPM
• Brake Horsepower
» Horsepower, Torque, Brake Specific Fuel Consumption, Brake Horsepower Loss
• Indicated Horsepower
» Indicated Horsepower, Indicated MEP, Indicated Torque, Mechanical Efficiency, Friction Output, Taxable Horsepower
• Air Capacity
» Air Capacity, Volumetric Efficiency, Street Carburator Size, Racing Carburetor Size
• Weight Distribution
» Wheel Weight Percentage, Increased Weight on Wheels
• Center of Gravity
» Location Behind Front Wheels, Location Off-Center on Heavy Side, Height of the Center of Gravity
• G Force
» G Force, Wheel Thrust, Centrifugal Force, Lateral Acceleration, Weight Transfer, Lateral Weight Transfer, Drive Wheel Torque
• Shift Points
» RPM After Shift, Drive Shaft Torque
• Quarter-Mile ET
» Elapsed Time, Miles Per Hour
• Overall Gear Ratio
» Manual Transmission Overall Gear Ratio, Automatic Transmission Overall Gear Ratio
• Instrument Error
» Actual MPH, Speedometer Error Percentage, Indicated Distance, Odometer Error Percentage
• MPH RPM
» MPH, RPM, Gear Ratio, Tire Diameter
• Tire Sizes
» Tire Diameter, Effective Ratio, Equivalent Ratio, Actual MPH, Indicated MPH
• Average MPH and MPG
» Miles Per Gallon, Miles Per Hour
• Modification Cost Effectiveness
» Mileage Modification Payoff
Have a look, I`ll stickie this soon.
This link is for:
• Displacement
• Compression Ratio
• Piston Speed
• Brake Horsepower
• Air Capacity
• Center of Gravity
• G Force
• Shift Points
• Quarter-Mile ET
• Instrument Error
• MPH RPM
• Tire Sizes
