Look into it. I have the wife's car and my truck done at least once or twice a year. It's worth every penny. Plus makes the upkeep much easier. pm me and let me know how you make out.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins and 4" Turbo Back MBRP On The Way
PAA#14
Get a bottle of detailer's prep glaze (with naptha as the base) and work in small sections. This will often clean up the problem as well as polishing (on white).
You should be able to find some under detail supplies in your phone book or online.
__________________ BEERING ENTERPRISES, INC. Expert Snow Removal & Ice Management
www.beering.biz '08 F350 Super Snow Fighter
'99 F350 Super Duty
you're going to have to strip off the wax to give it a good cleaning. Be ready to spend the entire day on it.
I used Collinite Sapphire Prewax Cleaner (No. 840) followed up with Liquid Insulator Wax (No. 845). You will not be disappointed, but to use the cleaner you do a small 2'X2" area at a time.
The object of this exercise is to get rid of the gunk that is on the top layer of the paint, under at least part of the wax. Most (but not all) of the waxes and glazes on the market have some form of a cleaner in them to get the crud off before leaving the final "slick". Like going to the dentist, there are a variety of cleaners and polishes that do the same thing (some better than others), to be followed by some form of top coat. (this is why the new car crowd will try to sell you paint protection, because for whatever value it adds, the annual polishing and "refreshing" makes everything look better)
Remember that the wax (or glaze) thickness is measured in angstroms, or fractions of a sheet of notebook paper, so its protection is not quite the armour many think it is.
'99 F350 Super Duty
We used to use rubbing compound to freshen up a faded paint job ... You might try that as it does not take too much at a time ... Just use light pressure ...
__________________
Current:
1986 Ford F250 XL Exploder 4x4 6.9 IDI Automatic
.. body by Rusty Crunchy
1986 Jeep Cherokee Pioneer Limited, 2.8L POS
Past:
1965 Chevy "Assembled" 1/2 ton
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
1967 Buick Special, 310 Wildcat, 2-speed slushbox
1967 Fairlane GT 500, 428 Cobra, twin turbo, NOX
You might try this stuff. Ultima Elastrofoam Paint Cleaning System
I use it in my business and have found it works as advertised. It will NOT damage the shine like clay can if you get a bit too aggressive, and if you drop it, just wash it off. Clay is trashed for paint once it hits the ground. Since getting this, all my clay is used for detailing stained wheels only.
__________________ "GREENIES" BEWARE-My goal is to use my full share of the available fossil fuels plus any shares left unclaimed!
06 F-150 Lariat SCREW
08 6.4 SD 250 King Ranch crew 4X4
05 Cadillac SRX
Special Touch first, Omega Glaze second, Blitz wax to seal..once a year on the Special Touch and the Omega Glaze.. I maintain rest of the year with just a touch up on the wax when it needs it.. It will shine like never before. One set will last you for years if you use it according to instructions.
As a truck driver for many years, I had quite a few loads that had to arrive in clean condition after having the load washed I would go over the worst bug stains with waterless hand cleaner and it worked everytime, I broke an exhaust pipe more than once and the soot covered my paint at the rear of my cab, waterless hand cleaner came to the rescue, It even cleans boats with no damage to the gel coat, pick a small area try it.(by the by no pumice.):-hu
