Toyota rusty Frame buy back
#61
Used Motor oil causes problems as far as the rubber mounts rotting out..This is why Tranny fluid is used
Now the factory Warranty it would not matter because no matter what Manufacturer makes the truck there rust proofing is a joke because the metal rust from the inside out..
Besides if the truck is properly oiled every year by the right pro your not going to have issues..
Sean...I wasn't refering to the Corrosion Warranty...I was referring to the applicator not being careful and possibly causing other problems with brake lines etc. that would not be covered by the factory warranty.
Your last sentence...at least in part...reflects what I was saying. If it is legal in your state...you need to have it done by someone who has the proper expertise in order to help prevent future problems.
#62
Vehicles in the coastal areas are often sprayed with lanolin oil here...
Tim, as for your statement regarding the box frame - its not necessarily the use of the box frame that makes it bad, its the application as to how it is used.
It needs to be the right specification metal, appropriate drain holes to ensure no "pooling" of water. It also has to be coated with the appropriate rust sealing coater.
#65
#66
#67
Not the greatest week for Toyota...
Toyota recalls 539,500 Corollas, Matrix in U.S. | Reuters
Toyota recalls 630,000 minivans in Japan - Forbes.com
#68
#69
#70
#71
#72
Jeez... the underside of my '01 SD is still pretty clean, and I've driven through 6 years of New York's salted roads for 3-4 months of the year here. And I don't even clean it until spring. The paint is still on my stock Ford hitch
When are people going to realize that certain brands are made to be driven and then crushed, and then there's other brands that you can actually keep for a long time and not worry about stuff like this?
I'll leave which brands fall into which categories to the reader...
#73
edtahaney
1983 - 2012 Ranger & B-Series
09-08-2015 06:07 PM
Faber
18
08-24-2015 01:03 PM
