Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-06-2008, 05:27 PM
SpikedCola SpikedCola is offline
SpikedCola is starting off with a positive reputation.
Flex-Fuel Sensor Technical Info
Ive been searching around, trying to come up with some info on the sensor. There arent any wrecking yards around here that have one, nor do I know anyone who has a working one on their truck (doing this for a friend - 2000 Ford Ranger w/ FlexFuel capabilities).
I know there are +12v, GND, and Signal lines - Im interested in the signal line. Id like to build an emulator for the sensor, as the truck will only ever be run on 87 octane. I need to send 40-60Hz (will try 40Hz for now, and scale it up if I need to) to the ECU, but what kind of signal was originally sent by the FFS? Square wave? Sinusoidal? What voltage, p-p was it?
If anyone can answer my questions it would be a huge help.
  #2 (permalink)
Old 04-06-2008, 07:20 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
Welcome. Check this thread out, maybe it'll help: http://www.ford-trucks.com/forums/60...uel-gurus.html
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 04-06-2008, 07:46 PM
Ahh, thats exactly what I needed! Doesnt even look hard. Just need a 555 in astable mode running around 57Hz sinking the Signal line.
  #4 (permalink)
Old 04-06-2008, 08:00 PM
Rockledge's Avatar
Go for it! Keep us posted on your progress. Good luck.
__________________
Ford Pics
  #5 (permalink)
Old 04-07-2008, 04:15 AM
WA1986F-250's Avatar
WA1986F-250 WA1986F-250 is offline
WA1986F-250 is starting off with a positive reputation.
Early GM FFVs that had the fuel ratio sensor sent square waves. Voltage if I remember correctly was 5v.
__________________
1986 F-250HD XL Supercab 2X4 351W C6 (Daily Driver) 300K+ miles no rebuilds no smoke
1986 F-250HD XLT Lariat Supercab 2X4 6.9L IDI Diesel T19 4spd 200K+ miles on truck 100K on rebuilt engine
1986 F-250HD XLT Lariat Supercab 4X4 6.9L IDI Diesel C6 300K+ miles on truck 40K on rebuilt engine
  #6 (permalink)
Old 04-10-2008, 12:27 AM
WARNING: I havent bread-boarded this circuit yet, it was all done in a sim, so test it before you build it. Also, I didnt include it in the picture, but 555 chips are labelled like this:
8 7 6 5
N -----
1 2 3 4
where N is the little notch in the side.
  #7 (permalink)
Old 04-10-2008, 09:51 AM
Rockledge's Avatar
Double post
__________________
Ford Pics
  #8 (permalink)
Rockledge's Avatar
Cool! But I have to admit that your schematic is kinda going right over my head.
I'm not sure I'm fully grasping things, so could you elaborate a little bit? For example, what do the labels mean (Vin, dis, ctl, ...)? And what are "E", "B", and "C"?
__________________
Ford Pics
  #9 (permalink)
Old 04-10-2008, 01:12 PM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
And what are "E", "B", and "C"? Emmiter, Collector and Base - terminals of P-N-P transistor used like electronic switch with "common collector". It is made in TO-39 ore SOT-223 body. Usually black. TO-39 body you can see at picture.
Vin - voltage in, ctl - controll....
Well, my opinion... I guess stock sensor generates other then square punses, but I think square pulses generator will work fine.
  #10 (permalink)
Old 04-10-2008, 01:14 PM
I'd like to make it ajustable. If you can hear nocking sound you can ajust timong. I added nock sensor to my EEC-IV aero but when I have detonation SPOUT line automaticly brakes.... Primitive, but works fine....
  #11 (permalink)
Old 04-10-2008, 04:11 PM
The labels arent really important - the numbers on the outside of the chip are the pin numbers, the labels are just there so you dont need to reference a datasheet to know what pin does what. But if youre wondering:
1 - gnd - Ground, low level
2 - tr - A short pulse high -> low on the trigger starts the timer
3 - output - During a timing interval, the output stays at +Vin
4 - R - A timing interval can be interrupted by applying a reset pulse to low (0V)
5 - Ctl - Control voltage allows access to the internal voltage divider (2/3 Vin)
6 - th - The threshold at which the interval ends (ends if thr -> 2/3 Vin)
7 - dis - Connected to a capacitor whose discharge time will influence the timing interval
8 - Vin - The positive supply voltage which must be between 5 and 15 V, high level
E - Emitter
B - Base
C - Collector
All three reference pins on a BJT transistor (in this case, a PNP one). The emitter is where current emits (flows out from), the collector is where current collects (comes into) and the base is the metaphorical "switch" that lets current flow (like a light switch - on and off).
While its a good idea, the problem with it being adjustable on-the-fly is that changing just R1 or R2 change the length of the pulse (ex. right now its on for an almost equal amount of time - but if you change just R1 or just R2, it may be "on" for 2x - 3x longer than it is "off"). The best way to do it would be to vary the capacitor - smaller values will increase the frequency, bigger values will decrease the frequency - but it is pretty hard to find variable capacitors in the uF range.
If you find that 57Hz is too low, and wanted to make it higher, use this calculator:
555 Timer Calculator
Sub in 4.7 and 10 for R1 and R2 (if you want - I picked those because they are common values) and play around with the capacitor's value to adjust the frequency.
I will prototype this tonight after work and take a few pictures, in case the schematic is confusing (Im sure it is if you dont work with them all the time). This one should be a bit easier (this one shows the actual chip layout and how you could route the wires):
  #12 (permalink)
Old 04-10-2008, 09:33 PM
Looks like the link to the pic I was trying to host is broken. "This one should be a bit easier:"
  #13 (permalink)
Old 04-11-2008, 04:45 PM
My friend drow old Soviet RAF van, he used to open engine cover and ajust ign. timing on-the-fly turning distibutor.... I used to do it in my aero but when I stopped on red only....
  #14 (permalink)
Old 04-11-2008, 11:30 PM
Woohoo, it works. I think. Going to swing by my uncle's tomorrow and scope the output, see if it is actually ~57Hz or not. Decided to try out my cellphone's macro mode, so here's a snapshot of the breadboard'd circuit:
  #15 (permalink)
Old 04-29-2008, 10:24 PM
Rockledge's Avatar
Quote:
So how's it working out so far?
__________________
Ford Pics
Tags
2002 , diagrams , flex , ford , fuel , ranger , sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
