AXLE ID NEEDEd - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
AXLE ID NEEDEd
Old 04-06-2008, 01:59 PM
BENG0924 BENG0924 is offline
BENG0924 is starting off with a positive reputation.
AXLE ID NEEDEd
I need an axle id the axle is in a 03 250 7.3. The axle tag reads
3 V 423 C
L73 10 5 2G31
Old 04-06-2008, 02:05 PM
05 super's Avatar
05 super 05 super is offline
05 super is starting off with a positive reputation.
Quote:
3 V 423 C
L73 10 5 2G31
THE 3l73 IS 3.73 GEARS AND A LIMITED SLIP
THE 10 5 IS THE SIZE OF THE RING GEAR 10.5"
CAN'T HELP WITH THE REST.
Old 04-06-2008, 06:40 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
05 super covered the important parts. The 3V423C is the plant code and 2G31 is the date code of where and when it was built.
Old 04-07-2008, 07:14 AM
So is this a Dana 60 or is it something else?
Old 04-07-2008, 07:53 AM
F350-6's Avatar
No, it's the Ford 10.5" axle not the Dana 80 or 135
Old 04-07-2008, 08:09 AM
Yea I somehow managed to get two posts going on this ne ways i have a leaky pinion seal and I am stuck on the repair i do not know how pull the wheel that the yoke bolts too is there a special tool ne hwlp would be appreciated
Old 04-07-2008, 08:18 AM
F350-6's Avatar
Is this what you're looking for?
Old 04-07-2008, 09:05 AM
This is the job but I have a different set up in mine there is a circular plate coming out with the pinion in the middle if i can remove the platei could get to the seal i definitely did not plan on pulling the pinion although it seems unavoidable i thought this would be a simple fix ie. remove drive shaft pull plate out replace seal otherwise i dont have required tools
Old 04-07-2008, 09:25 AM
ok I see what is going on I will get tools required and try to finish tonight update tomm hopefully
Old 04-07-2008, 10:34 AM
miker67's Avatar
miker67 miker67 is offline
miker67 has a good reputation on FTE.miker67 has a good reputation on FTE.
The procedures posted by F350-6 are the correct procedures. You will need to pull the yoke to do this. It is also of the utmost importance that you take that pre-removal preload measurement. Failure to do this can result in messing up your rear end leaving you stuck on the side of the highway.
Old 04-07-2008, 11:00 AM
What is the pre removal preload measurements?
Old 04-07-2008, 11:46 AM
has anyone else done this? is it neccesary to remove brake calipers? also I removed pinion nut prior to receiving these instruction can anyone give me the torque specs if i do not need to remove calipers i could get puller and pull flange and replace seal tonight but i do need the tq specs if anyone could help i hope I havent screwed up too bad
Old 04-07-2008, 12:29 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
There isn't a torque spec on the nut....it uses a crush collar.
I'm not sure what the rec. spec is off the top of my head for the rolling resistance.
Old 04-07-2008, 01:02 PM
What is rec spec? and how do I find out how much to tighten as well as do i need a new pinion nut Im pretty sure that i do
Old 04-07-2008, 01:04 PM
miker67's Avatar
However you do this, do it the same every time.
Place the rear of the vehicle on jackstands. If the tires are on for this measurement, make sure they are on for the reinstall measurement. If you pull the tires, then make sure the tires are off for the reinstall. Same principle with the calipers.
Next, using a torque wrench that measures in inch pounds, measure the force needed to rotate the rear end when you turn it via the nut in the middle of the yoke. Record this measurement and then during reinstallation you torque the pinion nut until you achieve this same amount of rolling resistance. This ensures the bearing preload is identical to what it was when you took everything apart.
The way I was taught, pull everything, wheels and calipers, then measure the rotational resistance before you pull it apart(IT being the pinion nut that holds the yoke on); however, different guys do it differently and you should be ok if you leave everything on, just so you do it the same every time.
HELP!! Rear axle ID tag question Farmtruckn 1967 - 1972 F-100 & Larger F-Series Trucks 7 08-02-2015 12:30 PM
Can 2000 F450 Rear Axle Assembly be Replaced with Later Axles? Wrktrk 1999 to 2016 Super Duty 3 04-12-2015 11:04 AM
97 f250 Axle I.D. help BKelley7.3L 1994.5 - 1997 7.3L Power Stroke Diesel 8 07-02-2014 11:43 AM
9" Rear Axle Bearing Confusion MixWizard 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-24-2014 05:23 PM
Rear Axle ID driveguy 1999 to 2016 Super Duty 6 03-14-2012 09:30 AM
Tags
2002, 3v423, 3v423f, 423, axle, code, duty, end, f350, ford, identification, nut, pinion, rear, super, torque, v423c
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
