2.3 L Duratec - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
2.3 L Duratec
Old 04-06-2008, 12:06 PM
xlsportrider xlsportrider is offline
xlsportrider is starting off with a positive reputation.
2.3 L Duratec
Well it has been about a month after my Ranger has been repaired. To bring everyone up to speed. I had the oil filter gasket spring a leak on me at 2 degrees fahrenheit. All the oil was lost and well, you can guess the results with only 10 seconds of running like this. Couldn't get it shut off fast enough.
I had, available to me, full use of a technical schools shop, as I am a student there. Labor was free.
Upon tearing the engine down I had found that the number 1 cylinders' rod bearing had spun scoring the crankshaft .010 of an inch. For some reason, the main bearings and journals weren't hurt in any way. Must be that the mains get oil first then the rods.
For machining. I had to have the rod journals cut .020 undersize. The kicker here is that NOT ONE bearing supplier has main bearings available for the 2.3 Liter Duratec engine. Something about they are on national back order. Also the rod, for that cylinder, had to be replaced. It was beyond repair.
Another shock was Ford doesn't service the lower end of this engine. It is what you'd call a "world" engine and is more or less a throw away engine. They require you, in their shops, to buy a short block as the only alternative for repair.
I had started a thread about special tools needed for this engine. I made both of them. The cam holding tool was made out of some 1/4 inch flat stock. The crankshaft timing peg (ESST no. 303-507) is 2-1/8 inches or 54 mm long. I made that as well by finding a blot that fit the threads in the engine block and welding stock to it. I ground it to the proper length saving lots of money in the process.
Reassembly went by uneventful. I replaced the clutch assembly, also, while I had it apart. I figured that the way my luck had ran, that was a wise thing to do.
Old 04-06-2008, 04:30 PM
crazypaw's Avatar
crazypaw crazypaw is offline
crazypaw is starting off with a positive reputation.
Wink
Welcome to FTE xlsportrider,
All input is valued here & yours is no exception.
Other than my observation, after reading your post, that you are also a smart, do-it-yourselfer like me & I have no more to offer but what I have read.
Just thought you should know.
Old 04-06-2008, 07:33 PM
Why thank you for that positive comment. I found this forum while doing some reaserch on the engine for the "special" tools needed. This is great site and the wealth of knowledge can be overwhelming. This incident happened on the way to work at 5 am. I just didn't catch the idiot light in time. Thankfully the engine wasn't a total loss. I work then go to tech school for diesel technology at night. The loss I suffered wasn't really needed. I was forced to drive, of all things my works Blazer for the duration of repairs. Thankfully they let me! That 8 to10 MPG for the month su.. well let's just say wasn't pleasent.
Fomoko1 I can't say enough about this mod. They have welcomed me and answered a few questions I had. To you, Fomoko1, I send out a sincere thanks.
I can't stop laughing at all the funny smiles
Old 04-06-2008, 07:59 PM
crazypaw's Avatar
Talking welcome again
Hi again xlsportrider,
I believe in fate & also doing for yourself and in us both I believe these facts do exhist.
And as for the FTE'rs...extraodinary!
And I hope you get your baby up & running again real soon!
Enjoy!
Old 04-06-2008, 08:18 PM
Crazypaw,
My Baby is up and running now for a month. I have since then put over 1000 miles on it. I will be changing the oil in the next week or so, as time permits. I know this is a really short change interval but it is like rebreaking in the engine to me. Now if I can only get my fingers to hit the darn keys my mind wants them to!
Old 04-06-2008, 08:25 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
What kind of filter(brand) was it that was leaking?????????? jd
Old 04-06-2008, 08:37 PM
Jimdandy,
It was Fram. I normally install only Motorcraft. For some reason I grabbed the Fram one the last time into the 'Zone.
Old 04-06-2008, 08:50 PM
Did you document the failure to Fram and ask them to make good on the defective filter? shady
Old 04-06-2008, 09:15 PM
Unfortunately I threw out the filter in cleaning up after repairs were completed. The kind gentlemen at my local 'zone (place of purchase) just more or less gave a What you want me to do about it shrug. I don't shop there anymore.
Old 04-07-2008, 07:41 AM
BSmitty's Avatar
BSmitty BSmitty is offline
BSmitty is starting off with a positive reputation.
Ah Fram, a testament to the attage "you get what you pay for", sorry it happened, but a great topic none the less. Welcome to FTE, there are some great and helpful folks around here, and it sounds like you'll be one of them! Glad to have you on board.
Old 04-07-2008, 08:57 PM
xlt4me xlt4me is offline
xlt4me is gaining momentum as a positive member of FTE.
I'm really suprised it spun a rod bearing that quick. Was it under a lot of load when it spun? Also, did you price out a new short block?
Old 04-07-2008, 10:49 PM
Quote:
xlt4me,
It was just pulling out of the local convienence store lot. It was like first gear time when I did a guage/light check. Saw the light flicker on and pulled over like twenty feet up the road. Most of that was rolling tike. I hit the key to off and coasted to the stop. Damage was already done.
Anyway, thanks for the welcome. I believe that if you can help out someone ,why not. I may have a solution to your problem as well as you may for a problem I might have. Make sence?
Will Gurtner
Old 04-07-2008, 10:54 PM
As for spinning the rod bearing that fast, The flow path for this engine has the oil pump up front directing oil flow to the rear of the egine first to the rear main that fees the no.4 rod ,ETC. The last to get any oil is the no.1 rod.
Will Gurtner
Old 06-07-2008, 05:53 PM
New "reman" short block, from FORD, is $1500+/- and $500 core charge for an engine that they do not service the bearing area on.
What irratates this situation is the main bearing are not available according to several engine remanufacturers that were contacted during this adventure. Guess they are hoarding them all for themselves.
Main & rod bolts Q fljab Ford Inline Six, 200, 250, 4.9L / 300 7 03-30-2015 06:28 PM
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 08:17 PM
Main Bearings or Block Damaged? tfurman6 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-22-2013 08:26 PM
Crankshaft specs? C.W Modular V10 (6.8l) 2 03-23-2013 01:49 PM
Looking for 351C crankshafts Rusty_S 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 02-22-2010 11:00 AM
Tags
2001, 23, 23l, bearings, block, change, duratec, engine, failure, flow, ford, liter, oil, ranger, short
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
