Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-06-2008, 04:24 AM
78bigbronco's Avatar
78bigbronco is starting off with a positive reputation.
Freeze plug leaking
I have what seems to be a very slight leak coming from the front freeze plug on the passanger side. I've never messed with freezplugs before, is this something that can be easily repaired?
I actually took the truck in to the mechanic last year since it was leaking realy bad (timing cover). I usually fix stuff myself but after changing the water pump once I didnt even want to bother again with the timing cover and just took it in. I told him then that the timing cover was leaking just about as fast as I could pour coolant in, and also a slight leak from the freezeplug. He fixed the timing cover and said nothing about the freeze plug, about 2 weeks more than the 3 days he quoted me, so I was impatient and didnt press on about the freeze plug. Its just leaking a little faster now than I'd like.
__________________
Tristan Stewart, KC2EBM
99 F-150 4x4 (daily driver, some mods) [Pic] [Webpage] [Video Clip]
78 Big Bronco 4x4 (a work in progress) [Pic] [Webpage]
78 F-250 4x4 (currently in dry dock)
84 Tbird [351W project still in dry dock] [Pic] [Webpage]
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-07-2008, 09:36 AM
BrianA's Avatar
BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.
I don't think actually replacing a freeze plug is a big deal. I've done it just a few times but it was in cases where I had clear access to the block.
In your case, accessing the area to drive the replacement freeze plug in might be a challenge.
In other words, I don't think the act of replacing it is very hard, but getting to it might be.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #3 (permalink)
Old 04-08-2008, 01:33 AM
I'm guessing thats means its something I cant do since I am not wanting to pull the motor myself. I'll just have to keep it checked frequently, seems to be loosing about an inch in the reservoir in about two weeks time.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
