Front Upper Spring Holder
I was asked to replace the upper front spring holder on a friends 94 F150 and I know that to get them out I have to grind the rivets out. After that the new ones just bolt(grade 8) in place of the old ones correct? Does anyone have a torque spec to tighten these bolts to? I have a haynes manual and it doesn't list one that I can find as they were not bolted on from the factory.
__________________
1980 F150 4x4 6" Skyjacker Suspension Lift 35" Pro Comp Mud Terrains 300 l6 Offy DP intake Holley 390 4bbl Comp Cams 260 cam
