trans temp sender
trans temp sender
I have a 03 SD 6L with the torqshift trans. I think the temp sender is on it's last legs. Today driving along the temp gauge spiked into the red and the check gage light and the tow haul light came on blinking. The tranny shifted fine so i kept drive watching the gage, it would come back to normal and then keep going down to cold and thats when to T/H light stopped blinking, and then starts all over again. My ? is could this be just the sender, and were would this tranny temp sender be located.
Thks..
Thks..
Over the counter price is around $75 and to give you an idea of the size of it, you could put about 30 of them in a pack of cigarettes. If your going to let Ford replace it expect to pay several hundred. If you decide to do it yourself, it's a fairly easy job and will only cost you the price of the sensor and 8 qt. of SP or LV fluid. If you do a search, you will find detailed instructions on replacing the sensor.
TFT sensor replacement
Thanks Guys for the quick feedback! I've dropped the tranny pan before to replace the internal filter at 100K. Will go ahead and get the TFT sensor...however, I forgot to mention that also the check engine icon light (lower left side) came on...I'm assuming that there must be a code thrown and that this will 'go away' once i replace the TFT sensor...
Cheers,
Gus
Cheers,
Gus
Cheers,
Gus
Cheers,
Gus
Remember to turn the sensor 90 degrees before pulling it down, it's T shaped on the end so it can twist lock in place. Easiest way to remove it is with needle nose pliers. P.S. keep your face clear when you remove it because another few oz. of fluid will squirt out, do you want to know how I know?
New TFT sensor did the trick
Thanks again guys for the tip on the TFT sensor.
I replaced it over the weekend.
I rotated it 90 degrees and pulled (considerable force) which caused the little plastic thermocouple housing to snap off inside the tranny.
But i was able to get the rest of it out with a very small pair of needle nose pliers.
Everything is back to normal now.
Cheers,
Gus
Cheers,
Gus
