mixing wvo ratio questions - Ford Truck Enthusiasts Forums
Old 04-05-2008, 05:01 PM
waltmiller222 waltmiller222 is offline
waltmiller222 is starting off with a positive reputation.
Talking mixing wvo ratio questions
What is a resonably safe wvo mix ratio to diesel fuel? My truck is and 89 7.3 completely stock I live in florida so there is no severely cold weather. With the price of diesel we need to cut the price down somewhere. Im thinking that any mixture if deemed safe for the motor would be a Big Help. Of course I wouldnt consider using it unless it was filtered and water free.
Old 04-06-2008, 12:55 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
The IDI is much more forgiving than a PSD so it may work for a while; however, running unheated WVO in any diesel is a risk for coking and catastrophic failure.
Old 04-07-2008, 11:12 AM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
I'm in South Alabama, not far from Florida, I burn 50-100% WVO in my 88, but I start on Diesel Fuel, then switch, no conversion, the oil will get plenty hot but going through the manual lift pump and the Injector pump, it will get plenty hot.
Old 04-07-2008, 05:38 PM
Phydeaux88's Avatar
Take note of what I said and realize that AndysFords has an IDI engine in that 88 7.3L F350
New to me truck, want to run WVO/diesel mix Shiftyride Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 07-11-2015 10:17 AM
Best Way To Heat WVO to Make Biodiesel sirnobody Bio-diesel, Propane & Alternative Diesel Engine Fuels 10 04-20-2011 11:04 PM
WVO Blends IceboxFX Bio-diesel, Propane & Alternative Diesel Engine Fuels 31 06-29-2008 05:33 PM
The pros and cons of homemade biodiesel vs wvo. derherr65 Bio-diesel, Propane & Alternative Diesel Engine Fuels 66 04-23-2007 08:23 AM
Is wvo safe for 89 f350? BOB ROSS Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 02-01-2006 10:46 AM
Tags
69l, diesel, engine, fuel, mix, ratio, safe, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
