Harmonic Balancer questions - Ford Truck Enthusiasts Forums
Old 07-24-2002, 02:25 AM
chickenass chickenass is offline
chickenass is starting off with a positive reputation.
I need to replace my harmonic balancer on an '83 Ford Bronco with a 351w and duraspark3 ignition system.
The old one is part # e1te c3a. e=80's 1=1 t=truck e=engine part
The one I pulled off an '82 ltd is part # e2te d3a.
The weight on the two seem different. I've read that they should all be the same weight. Does anyone know what the c3a and d3a stand for or anyother way to find out if these match.
Old 07-24-2002, 10:06 AM
71swissaqua's Avatar
71swissaqua 71swissaqua is offline
71swissaqua is starting off with a positive reputation.
Are you sure the 82 LTD was a 351W and not a 302? I don't remember when thay changed the weights and which way they went on the 302's. I'll bet Torque King does though, might want to get up with him.
Clint
Old 07-24-2002, 11:32 AM
Brian Brian is offline
Brian is starting off with a positive reputation.
The weight of the balancers may be different but it is the imbalance weight that is important. The 351W uses a 28 oz as did the 302 through 76 I believe. The trucks sometimes had a wider balancer which made it heavier but also had more surface area on the rubber to provide better damping. For a fast reving motor you would want to the lighter/thinner balancer so the angular inertia would be less. For a torque motor the thicker balancer is better becuase it has more inertia.
Old 07-24-2002, 02:18 PM
Thanks for all the help. I actually only needed to replace the plate on the rear of the damper. After playing with it for a while I fund this was a seperate piece. It runs much better know that it's firing on all 8 cylinders instead of only six. Thanks again for the help.
James
Old 07-24-2002, 03:48 PM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
For the record, the 52 oz imbablance started in 1981, on 302's only. I like that comment about angular inertia, now we're talkin'! TK
Old 07-24-2002, 07:17 PM
TorqueKing's Avatar
harmonic balancer pulley retired ironworker FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 02-27-2015 09:12 PM
Harmonic Balancer E4TE-B3A mikepedersen17 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 03-26-2012 09:46 PM
Help Number Dummy thrifty 1961 - 1966 F-100 & Larger F-Series Trucks 4 12-23-2011 03:50 PM
Spare Part#'s What do I have? Dan76'F100 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 06-17-2003 12:54 PM
460 ID Help (I Have The Numbers) cyberdiamond Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 10-23-2001 11:17 PM
Tags
289, 302, balancer, block, e1tec3a, e2ted3a, engine, ford, harmoncia, harmonic, oz, question, replace, small, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
