F250 with 5.4 Overheating - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-05-2008, 01:03 AM
boilergrad25 boilergrad25 is offline
boilergrad25 is starting off with a positive reputation.
Here is my problem. My truck overheated the other day and the antifreeze level was ok, so I replaced the thermostat. I got it replaced put antifreeze back in it, let it idle for awhile and then drove it around for 15 mins no problem. The next morning I drove off and it over heated again, but the thing is as soon as i vent the coolant tank and start the truck back up it show running normal on the truck and will not overheat again as long as im driving it. Everytime I shut it off and drive it again it repeats this.
I have no clue what to do. Is the new thermostat I put in bad?
Old 04-05-2008, 01:52 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Welcome to FTE!
What Year SD 5.4L do you own? Is it the GREEN or GOLD anti-freeze?
Do you actually see steam rising when your SD is overheating? If not, then I suspect the temp gauge is the problem.
biz
Old 04-05-2008, 08:17 AM
It is a 2003 SD. Yes there is steam coming off the truck. It has the yellow/orange colored antifreeze.
99 f250 5.4 gas coolant issue zjmj17 1999 to 2016 Super Duty 2 12-10-2016 06:01 PM
2003 Ford Explorer XLS 4.0 RMeans Explorer, Sport Trac, Mountaineer & Aviator 2 09-14-2016 03:48 AM
99 Ranger Overheating Problems. paerhardt Ranger & B-Series 21 12-13-2015 11:55 PM
heater not blowing hot air Propr801 1987 - 1996 F150 & Larger F-Series Trucks 6 12-23-2008 06:49 AM
heater not blowing hot air Propr801 Cooling, Heating, Ventilation & A/C 1 12-19-2008 07:51 PM
Tags
05, 54, f250, f350, gas, heats, overheating
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
