Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-04-2008, 08:21 PM
base497 is starting off with a positive reputation.
All Four Power Locks Quit At Once
I have a 2003 F150, Crewcab and all my locks quit working at once, however, the drivers side will unlock with the remote but not lock. The door switches do not work (lock or unlock) but I can hear the clicking at the remote keyless/ security module. I hear the same click when using the remote. My repair manual (Chilton) addresses what to do if you don't get the click but does not say what the problem is if you do get the click. I've check the basics, wiring, relay and fuses. Any help would be appreciated.
Ken
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-04-2008, 08:49 PM
gbadgley is starting off with a positive reputation.
Does it have a "lock out" switch that locks the other 3 door switches out? that could be bad if so. Greg
__________________
If I can't fix it, I can screw it up so bad no one else can either!
  #3 (permalink)
Old 04-04-2008, 09:54 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I looked it up in the manual, and they have listed a SuperCrew and a Harley Davidson as having 4 doors. The diagram shows the passenger side front and the passenger side rear tied together. They show the two driver's side doors tied together as well. There are only two outputs from a "Central Security Module".
The door switches run into this module, and this module drives the door locks directly. This module is powered by fuse #115, 20 amp in the underhood fuse box when you have the 4 door. This module is located behind the dash panel, left hand side near the steering column.
Ford lock actuators are not known for their longevity either.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 04-04-2008, 10:19 PM
Good thought but it does not have the lock out switch for the 3 doors but does have the lock out for the windows.
  #5 (permalink)
Old 04-04-2008, 10:29 PM
Dave, I replaced the #115 20 amp fuse with another in the box and it had no affect. I found the security module and remove the clamps so I could position the module to confirm the "clicks" (when door switch or remote is depressed) where coming from the module and they are. I am beginnig to suspect a faulty module but how does one know for sure? Ford wants $189 for a new one but that is a lot of money to use for trouble shooting. I know some threads point to the actuators, however, I find it difficult to believe all four would go at once. Any thoughts? Appreciate your earlier reply!
  #6 (permalink)
Old 04-04-2008, 10:46 PM
Franklin2's Avatar
I think I would get a small battery charger and rig two little small wires to the charge clamps, unplug the connector to the security module, and stick the little wires up in the connector to see if you can make the locks work. I just looked closer at the wiring diagram, and it seems they have a separate feed for the driver's door, and the three other doors are all wired together.
The drivers side front are the red/orange and a pink/black.
The rest of the doors are the pink/black and pink/orange.
I believe if you hook the wires one way, the lock will lock, and then reverse the wires, and they will unlock.
__________________
Dave F
  #7 (permalink)
Old 04-04-2008, 11:06 PM
I like the sound of it. I am currently out of town but will try in Monday when I get home and let you know. Thanks!
Ken
  #8 (permalink)
Old 04-05-2008, 09:26 AM
You're right - Brain cramp. Greg
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
