i got axle code 19 and 20 inch rims and i got the rpms of a 3.73. people say 3.55 are kind of doggish and i don't see that on regular driving but i do when i'm trying to merge onto highways and trying to pass without punching.
I would say it is due to the tire size. the overall diameter is smaller then that of the 18" wheels/tires. You end up with about the same ratio as the 18's with 3.73's. I figured it out a while back and you would be 50rpm lower with that tire/gear ratio then that of the 18's with 3.73's. I think a 4.10 gear would be much more ideal.
