Going from 4.1 to 3.7 or so. What tires do the trick?
With stock tire and my gear ratio I get in to very hi RPMs cruising on the freeway.
I don't tow anything more than 6K,
What size tires would bring those revvers down?
Hopefully noting to extreme., just wan't to drop RPM by 200-300.
Dinikin
Dinikin
Look here:
Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Be sure to use the tire diameter...measure it.
It doesn't take much to get the wrong results
