Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-04-2008, 12:59 PM
cobraguy is starting off with a positive reputation.
Carb choice
I've got a 460 to put in my 61 unibody. It will be mostly stock D1VE block,D3VE heads, Stock CI manifold, headers,3" exhaust. I have an Edelbrock 1405 (600cfm) on the 302 thats in it now. Yesterday I scored a Holley 650 DP list #4777 manual choke, mech sec. I want it to be a driver and have been pleased with the Edelbrock. The Holleys I've had in the past required tinkering alot. I'm older and lazier now but like to smoke the tires once in a while. Which carb would you guys recommend.
__________________
61 Unibody preject/driver
62 Falcon 2dr
63 Ranchero
01 Saturn SC1 plastic Vega
01 Taurus Wagon, Momma's Silver Bullet
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-04-2008, 09:31 PM
jade79 is starting off with a positive reputation.
If it's basically stock, I'd try the edelbrock you have now. They offer a tuning kit with various metering rods and jets to get it tuned correctly for the 460. My 302 2 barrel can "smoke the tires" so I'm sure the 460 won't have a problem regardless.
  #3 (permalink)
Old 04-04-2008, 10:34 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
DPs belong on race only applications an work poorly on street engines. As much as it pains me to say this, use the Edelbrock. Damn, that's hurts a Holley guru to say that.
__________________
Bear 45/70
Gimp Racing
  #4 (permalink)
Old 04-05-2008, 09:39 PM
monsterbaby's Avatar
monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.
LOL Bear
He is right though the DP carb is more of a strip type of carb, you can run them on the street but unless your planning on a lot of 5000+rpm that 600 edelbrok will work just fine and probably get you better economy (for what thats worth with a 460) and honestly on the low end it's going to give you more torque up to around 3000.
__________________
Dying's not so bad
It's living that will kill you off
  #5 (permalink)
Old 04-05-2008, 09:53 PM
OK thanks I'll just rebuild the Holley and Ebay or craigslist it. Anybody here want a Holley 650
__________________
62 Falcon 2dr
63 Ranchero
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
