Lean on Bank 1 & 2 - Ford Truck Enthusiasts Forums
Lean on Bank 1 & 2
Old 04-04-2008, 11:16 AM
zman764 zman764 is offline
zman764 is starting off with a positive reputation.
Lean on Bank 1 & 2
I have been getting the lean on bank 1 code for about a year. But I never saw a change in mpg or anything so I've left it alone. Now my last 5 - 10 tanks of gas I've been getting 12mpg on everyone I normally get 15. Just wondering what do I need to do to remedy my lean on bank 1 & 2 problem which I am hoping is tied to my low mpgs?
The truck is a 97 4x4 4.6L with over 217k miles on it.
The plugs are fine they only have about 20k on them.
Just replaced the inline fuel filter a few months back.
Air filter is clean.
I have cleaned the MAF recently as well.
Thanks.
Old 04-04-2008, 11:28 AM
jimm66's Avatar
jimm66 jimm66 is offline
jimm66 is starting off with a positive reputation.
I'm wondering if you use a fuel system cleaner (injector cleaner)? If so what brand? I have been wanting to ask this question. I don't mean to jack your thread but it could be related.
I heard not to use the cheap stuff. Maybe something like chevron?
Old 04-04-2008, 12:37 PM
I don't recommend fuel system cleaners. I have read articles and watched videos where an independent organization would take several different products and test them on identical cars. Log the mpgs before the treatment and after. They were using dynos to simulate driving & monitor hp. They did like 5 or 6 different brands and none of them made an improvement and a couple actually lowered hp.
I have used Lucas fuel system cleaner to try & get more mpg & get rid of a knock. It didn't do either. I noticed no difference. IMO all it did was make me have to replace my fuel filter sooner.
So any ideas on my Lean engine?
Old 04-04-2008, 12:58 PM
ranger88a ranger88a is offline
ranger88a is starting off with a positive reputation.
Check the pcv valve tube to where it connects to the intake and make shure it's ok.
Old 04-04-2008, 02:15 PM
F4L956 F4L956 is offline
F4L956 is starting off with a positive reputation.
Wink
maybe its time for some new intake gaskets! that is alot of fine miles hope mine gets there without any problems! OR could just be some vacuum line leaking out! GOOD LUCK!
Old 04-04-2008, 02:39 PM
chrisf250-460 chrisf250-460 is offline
chrisf250-460 is starting off with a positive reputation.
i would check for vacumm leaks as mentioned above.the pvc hose where it attaches to the back of the intake-90 elbow.check the egr valve for proper opening and closing,make sure the diaphram is working properly,and check the dfpe sensor,could be clogged up, and check lines going to dpfe sensor,mine were clogged as well.hope this helps
Old 04-04-2008, 06:02 PM
jimm66's Avatar
ZMAN Let us know what solved your problem.
Old 04-06-2008, 12:30 AM
stanlucky stanlucky is offline
stanlucky is starting off with a positive reputation.
check for broken bolts on ex. before the cats
Old 04-06-2008, 10:51 AM
I know the PCV hose is fine I have it hose clamped b/c it used to just flop around.
I am pretty ignorant about vacuum systems & the egr system.
I cleaned the egr ports for the famous "insufficient egr flow" code.
So I need a good bit of input to do what ya'll have suggested.
1.) Replace the pcv valve.
2.) Where are the vacuum lines & how do I check them?
3.) How do I "check the egr valve for proper opening and closing, "make sure the diaphragm is working properly",and "check the dfpe sensor,could be clogged up, and check lines going to dpfe sensor"
4.) Should I replace the 2 O2 sensors on the exhaust?
5.) Oh dear gawd plz not replacing gaskets around the intake manifold..... way more work than I want to put into the truck right now haha.
Thanks Guys
Old 04-06-2008, 11:12 AM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
have you ever replaced the upstream o2 sensors?? i heard they should be replaced every 80k to 120k. also it might not hurt to check fuel pressure and make sure thats inline.
Old 04-08-2008, 02:19 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
The 90 degree bend in the PCV hose at the back of the intake manifold is the prime suspect. The hose tends to burn through at the bend in the hose. Check this out first. Otherwise, check for air leaks in the air ducts after the MAF sensor but before the throttle body. Leaks in this area will result in unmetered air in the intake tract. This would be more air in than the MAF is sensing and thus the lean codes for both banks. Good luck!
04 Expy Bank 1 and 2 lean xSgtRenegadex 1997-2006 Expedition & Navigator 19 03-16-2014 08:15 PM
96 4.9l P0171 82inline6 1987 - 1996 F150 & Larger F-Series Trucks 3 01-15-2014 12:04 AM
lean bank 1 and 2 fatboyreyn 1997 - 2003 F150 7 07-10-2010 07:12 PM
96 F150 5.8 Running lean "bank 1 & 2" ford5.8 1987 - 1996 F150 & Larger F-Series Trucks 3 04-14-2009 11:51 AM
P0171 (System too lean bank 1), P0174 (System too lean bank 2) Octane 1997 - 2003 F150 16 09-27-2008 12:35 AM
Tags
1, 100, 2004, 54l, bank, bank1, banks, e150, f150, ford, fx4, lean, mercury, sable, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
