How do I adjust my choke
I bought a 1987 E350 in a motorhome. I think it has an electric choke but I can't figure out how to adjust it. I removed a ton of emmission crap and the engine runs great but the choke just stays on a little to long, once it warms up everything is fine. There is one screw on tthe bottom i removed it but the choke will not turn. Any idea's???
The choke cover is retained by breakaway head "tamper-proof" screws so if it hasn't been touched since the factory, You will see conical nubs (don't know how else to describe them)
I used a Dremel tool to cut a slot in each so I could remove them w/ a screwdriver.
There should be 3 screws IIRC.
*edit*
This a somewhat blurry pic of the choke side of my 4180. You can see I replaced the screws w/ slotted brass ones.
Flickr Photo Download: IMG_1895
*edit*
bigland
11-27-2009 05:55 AM
