How do I adjust my choke - Ford Truck Enthusiasts Forums
Old 04-03-2008, 10:46 PM
urcysk urcysk is offline
urcysk is starting off with a positive reputation.
I bought a 1987 E350 in a motorhome. I think it has an electric choke but I can't figure out how to adjust it. I removed a ton of emmission crap and the engine runs great but the choke just stays on a little to long, once it warms up everything is fine. There is one screw on tthe bottom i removed it but the choke will not turn. Any idea's???
Old 04-04-2008, 03:03 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
The choke cover is retained by breakaway head "tamper-proof" screws so if it hasn't been touched since the factory, You will see conical nubs (don't know how else to describe them)
I used a Dremel tool to cut a slot in each so I could remove them w/ a screwdriver.
There should be 3 screws IIRC.
*edit*
This a somewhat blurry pic of the choke side of my 4180. You can see I replaced the screws w/ slotted brass ones.
Flickr Photo Download: IMG_1895
Old 04-04-2008, 07:55 AM
pedant
I forgot to add....Welcome to FTE urcysk!
Old 04-04-2008, 08:29 AM
Thanks for the reply, thats my carb, I will get a tool to remove those scews today. Those tubes on either end of the top of the carb can they be plugged off now that the emission stuff is removed or do they need to vent
Old 04-04-2008, 08:39 AM
pedant
I would think you do need some kind of vent.
You might tie them both together into a "Tee" fitting and keep it under your aircleaner, that would look sano.
Old 04-04-2008, 09:03 AM
should I hook them into the air cleaner so it sucks the vapours in
Old 04-04-2008, 09:21 AM
pedant
No, you wouldn't need, or want to do that.
I was just thinking it would look more 'right', and not cost anything.
Old 04-04-2008, 09:50 AM
thanks alot for your help
Old 04-04-2008, 09:53 AM
does fuel actually come out of those vents because wright now I have them blocked
Old 04-04-2008, 10:03 AM
pedant
It shouldn't, if the floats are OK, but there is the chance that it could if the float sank or the seat was bad.
Old 04-04-2008, 11:35 AM
so I should leave them unblocked then
1979 ford ranger 351m carb ? bigland 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-27-2009 06:55 AM
Choke not pulling off alconk 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-18-2008 11:41 AM
How to adjust auto choke jenks47 Fuel Injection, Carburetion & Fuel System 1 01-31-2004 09:53 PM
choke? 78bronco Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 04-16-2002 08:26 AM
HOLLY 4180 choke tamarackstyle 1978 - 1996 Big Bronco 1 12-02-2001 04:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
