2000 F150 front differential
I don't have a clue, but I have seen repeated posts saying to pull the front cover and lube everything up. If you have vacuum it might just be something stuck. Also, if you search the forum there are a bunch of other posts. The one below seemed pretty helpful.
https://www.ford-trucks.com/forums/7...t-working.html
Good luck.
Good luck.
Do as the other guys have said. I removed mine the other day to diagnose the same thing. Remove the plastic cover with the three 10mm bolts so you can see what is going on. If you don't have a vacuum pump, I just bought one to diagnose this and an EGR valve problem. It has already paid for itself. I just hooked the hose up to each port on the actuator that moves the arm on the axle. It worked fine hooked to the pump. I followed the vacuum hoses up and discovered I had a crack at one of the fittings. Easy fix. Originally, my actuator seemed stiff so I used some PB Blaster and ran it in and out with a small prybar and it seemed to free it up. Hope this helps.
neilc88
11-30-2012 07:00 PM
RA81222
06-26-2008 01:56 PM
oz9609
12-24-2004 09:35 PM
