Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 04-03-2008, 08:34 AM
abetterkyle abetterkyle is offline
Garage is empty, add now
abetterkyle is starting off with a positive reputation.
anyone do this conversion?
hey guys, i have a 2000 E-450 shuttle bus with the 7.3L, that i am wanting to convert to run on WVO (wasted vegetable oil) or SVO (straight vegetable oil) the reason being is this shuttle gets horrible gas mileage and as a traveling band, it would be awesome to save fuel cost. I'm going to check out the alternative fuel forum here, just going to see if anyone knows of anywhere in Ok i could talk to about it or not! thanks guys!
  #2 (permalink)
Old 04-10-2008, 09:15 PM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.
There really isn't a conversion process. All you need to do is acqire two 50 gallon drums (or whatever side), some 1" flex hose, a pump, a 50 micron filter and a 10 micron filter and you're good to go.
It is recomended that you swap out the fuel lines as the vegi-oil is a little harder on the rubber.
Connect the hose to barrel A (dirty), attach the other end of the hose to the 50 micron filter (standard pool filter that you can buy at any hardware store), then from the 50 micron filter to the pump, then to the 10 micron filter, then into your clean tank. Then you're good to go. I have a buddy that has this EXACT set-up and has been using it for about 2 years.
One recommendation is that when it is cold out, you may want to take a few gallons of your oil and heat it up to a couple hundred degrees, then dump it in with the rest of your oil in barrel A, this will allow the oil to flow better.
STan
  #3 (permalink)
Old 04-11-2008, 01:18 PM
so u dont have to convert anything? so like it'd run on SVO right now? What about the dual fuel systems where it starts on diesel and then switches over to the wvo? what you said just seems too easy!
  #4 (permalink)
Old 04-15-2008, 03:06 PM
Traxxis's Avatar
1994 Ford Ranger
My Garage
It's easy as pie.
The dual fuel system is because the veggi oil coagulates (gels) at a higher temp than diesel, therefore they start the vehicle on diesel and run it for a while and warm up the veggi oil.
Trust me, that all there is to it.
Stan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
