rear differential - Ford Truck Enthusiasts Forums
Southwest Region Arizona, New Mexico, Oklahoma, and Texas.
rear differential
Old 04-03-2008, 01:57 AM
danquin1 danquin1 is offline
danquin1 is starting off with a positive reputation.
rear differential
Does anyone know what is involved in changing the rear diff oil in a 2000 expy, EB 2x4
Old 05-23-2008, 05:34 PM
Gage2502's Avatar
Gage2502 Gage2502 is offline
Gage2502 is gaining momentum as a positive member of FTE.Gage2502 is gaining momentum as a positive member of FTE.
Ya its really easy, First take the cover off and let the oil drain in a pan, make sure that you remove all the gasket from the housing and the cover, now would be a great time to paint the cover just make sure you let the paint dry. Use RTV for the new gasket on the housing let it dry for only 5-10min and bolt the cover back on. The fill plug is on the drivers side front of the Dif housing you can use the 3/8" ratchet to remove the fill plug and add the new Diff oil I would use Royal Purple 75W140 its great stuff and its only $10qt you will need 4qts I believe. If you have any more question let us know.
~Gage~
any ideas on repairing rear power window streaksf 2004 - 2008 F150 6 11-29-2012 04:34 PM
Breather bolt in the nine inch rear end Bigbruce 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-24-2012 10:41 PM
no rear heat baller9409 Excursion - King of SUVs 6 07-24-2012 11:34 PM
how to remove rear panels fgials Excursion - King of SUVs 14 12-21-2011 06:52 PM
351W Rear main seal F150 freefallin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-15-2007 10:26 AM
Tags
03, 1948, change, diesel, diferential, differencial, differential, differentil, expedition, ford, oil, rear, schematic, schenatic, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
