Code 401 Egr problems - Ford Truck Enthusiasts Forums
Old 04-02-2008, 08:46 PM
truckmonger1 truckmonger1 is offline
truckmonger1 is starting off with a positive reputation.
My check engine light came one so I had it scanned and came up with #401 which is insufficient air flow. I pulled the valve off and it appears it has been replaced before. It was not all carboned up, the vacuum pulled the valve fine and it sealed liquid tight when closed. What else could set this code? Could it be the DPFE? How can that be tested? Any thoughts. Thanks.
Old 04-02-2008, 09:43 PM
SICKANDTWYSTED's Avatar
SICKANDTWYSTED SICKANDTWYSTED is offline
SICKANDTWYSTED is starting off with a positive reputation.
do a seach youll find tons of info on it. in a nutshell the first thing you need to do is clean out or egr ports in the throttle body neck. its the most likely prob since your millage is over 50k. second most likely thing is the egr pressure sensor on the egr tube. very common for these to fail but you need to replace it with the updated Ford part in a plastic case not an aftermarket one. Hardly ever is the egr the cause for this code, but you can check it by applying vacc to it while the motor is running. this should make the motor stall or close to it.
Old 04-03-2008, 06:51 AM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is gaining momentum as a positive member of FTE.
Like sick&twysted said. Start by cleaning the EGR ports in the throttle body. If that doesn't fix it, change the DPFE.
Old 04-03-2008, 01:04 PM
hafwhit hafwhit is offline
hafwhit is starting off with a positive reputation.
Talking
Carbon build up on the passages from the EGR valve in the Intake to Throttle Body spacer could be your problem. I bought a 1999 F-150 a month ago and it had 180,000 miles on it. When I removed the spacer and I looked inside I found so much carbon build up that it looked like leaves growing from the passages. The cost of a couple of gaskets and some throttle body cleaner may be all you need. I took some pictures and will see if I can get them online when I get home.
Old 04-03-2008, 02:04 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
I posted a very good explanation on how to troubleshoot this a couple of days ago in the Expy/Navi forum (same engine).
See if you can locate it.
Steve
Old 04-03-2008, 10:29 PM
Thanks for the tips. I looked on Rock Auto and found the "EGR Pressure Feedback sensor". Is this the same as the DPFE? I see it right in front of the EGR valve. Is there no way to test this? I did check the going to it and they are OK. Thanks.
Old 04-03-2008, 11:20 PM
Lance1601 Lance1601 is offline
Lance1601 is starting off with a positive reputation.
Yes it's the same thing but what's weird is that their motorcraft part is way cheaper than what the dealer has.
Old 04-04-2008, 04:10 PM
Wink
Here are some before and after pictures of the EGR passages on the Throttle Body to Injector Spacer when I cleaned it.
What it looked like when I removed the spacer!
What it looked like after cleaning it.
Old 04-05-2008, 07:02 AM
Joe Finn's Avatar
I would clean the TB EGR ports first (it's free and takes bout an hour). After that, reset the code and see if it comes back. If it does, then you can spend $$$ on the DPFE.
Old 04-05-2008, 10:31 PM
dubble-dee dubble-dee is offline
dubble-dee is starting off with a positive reputation.
Old 02-17-2013, 01:38 PM
Butch Pressley Butch Pressley is offline
Butch Pressley is starting off with a positive reputation.
What do you use to clean the ports with?
P401 greenheads 6.0L Power Stroke Diesel 11 03-17-2015 09:47 PM
401 & 402 codes at the same time? Freeser 1999 to 2016 Super Duty 4 03-12-2015 09:39 AM
PO401 code and misfires on 3 and 7 2oo1 4x4 1997 - 2003 F150 1 05-15-2014 08:05 PM
Error codes out the wazoo!!! torranosaurus 1997 - 2003 F150 2 01-23-2014 08:42 PM
1998 Ford Expedition fast idle chriskb 1997-2006 Expedition & Navigator 0 03-07-2004 09:32 PM
Tags
150, 1997, 1999, 401, code, dump, egr, f150, f450, ford, front, installing, pressure, problems, truck, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
