Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #31 (permalink)
Old 05-16-2008, 09:45 PM
camodown is gaining momentum as a positive member of FTE.
Try tapping into the white line. It works better imo.
  #32 (permalink)
Old 05-16-2008, 09:47 PM
BanksPSD's Avatar
Still Learning
BanksPSD is starting off with a positive reputation.
Quote:
Originally Posted by sflem849 View Post
Are you sure the valves are opening/closing when they should?
No felt difference or no difference with a thermometer?
I used a thermostat and I saw no difference. I'm not sure if the vave is working the right way but I followed the instructions on this forum:
http://www.ford-trucks.com/forums/51...ditioning.html
__________________
Allen
2002 F250 Auto 2WD - PAA Member #40
4" exhaust, Sniper Tuner, 3G Pod (PSI, Trans, Pyro), AIH Delete, S.S. HPX Line, Precision TC
BD Valve Body, 6637 Mod, Zoodad Mod, CCV Mod, Anti-theft MOD, AC Mod.
  #33 (permalink)
Old 05-16-2008, 09:51 PM
BanksPSD's Avatar
Still Learning
Quote:
Why do you think it wors better? I'd like it to only "work" in the AC/MAX-AC positions... I use the Vent when it is not too hot/cold to run the AC... Right now I think the AC only works when its on MAX-AC, AC, Vent only (no heat what-so-ever)...
__________________
Allen
  #34 (permalink)
Old 05-18-2008, 12:34 AM
Well, I guess I should have worded that better. For me, the white line works better because the white line has vacuum applied on max a/c and off, meaning the heater core wouldn't have any supply of hot coolant in those positions. If you tap into the red line, you are having full vacuum on max a/c, a/c, panel, and panel floor causing cooler air discharge but no heat control over ambient temps. This means you will only get heat in floor, floor defrost, and defrost. Also, in the off position, the heater core will still have coolant circulating.
  #35 (permalink)
Old 05-18-2008, 12:41 AM
The A/C compressor is active above 43* F in MAX A/C, A/C, Panel/Floor, Floor/Defrost, and Defrost, assuming you have manual A/C. Of course, EATC uses completely different commands. Max A/C is the most efficient when using A/C because the air is recirculated so less heat dissipation and de misting has to take place causing the compressor to run less. You probably won't need heat much in that part of Tx now that I think of it...
  #36 (permalink)
Old 05-18-2008, 01:15 AM
1996pwrstrk's Avatar
Ar Chapter Ldr
1996pwrstrk has a very good reputation on FTE.1996pwrstrk has a very good reputation on FTE.1996pwrstrk has a very good reputation on FTE.
What temp readings were you getting and what was the ambient temp ?
__________________
Dave
1999.5 F350 XLT,cc,drw,4X4,a pair of levers,4:10 LS
6637 mod, 4"MBRP cool duals,2 pos chip, ss hpx,ITP pre-pump with holley red pump ,140 V IDM , WW, EBPV deleted,AIH deleted, Autometer gauges
Join the Arkansas Chapter Here
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
