Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-02-2008, 02:22 PM
sflem849's Avatar
sflem849 sflem849 is offline
Garage is empty, add now
sflem849 has a good reputation on FTE.sflem849 has a good reputation on FTE.
The GPR LED Mod as made famous by WMRiceman
The GPR LED Mod
As made famous by WMRiceman on FTE (Mark)
I thought I would put together a how to on the GPR LED mod. I struggled with my first install due to several minor problems. The majority of parts were gathered at Radio Shack, the rest were donated by work. Here goes!
I have attatched .pdf's that are a little more detailed and can be printed out for use in the shop. Page one is your parts list to take to Radio Shack and the rest are the directions.
Parts
1 – LED (Radio Shack has two sizes and three colors in each size. These are the 5 mm size)
5 mm Red LED w/ Holder (p/n 276-0270)
5 mm Green LED w/ Holder (p/n 276-0271)
5 mm Orange LED w Holder (p/n 276-0272)
1 – Automotive Inline Fuse Holder for 5x20 mm fuses (p/n 270-1238)
1 –500 ma (½ Amp) 5x20 mm Fuse (p/n 276-1061)
3 – Red Butt Connectors
1 – Large Red Ring Terminal
1 – Medium Red Ring Terminal
18 ga or Larger Red Wire (Length dependent on mounting location)
18 ga or Larger Black Wire (Length dependent on mounting location)
1 – ¼ ID O Ring (Optional)
(The parts I bought. I chose the orange to match the WTS light. IIRC they were about $6)
Tools
Drill
7/32” Drill Bit
Stripper/Crimper
¼ Drive Ratchet
5/16” ¼ Drive Socket
1/2” ¼ Drive Socket
Directions
1 – Find a suitable location for the LED and drill your hole.
Be sure to check behind the hole for clearance and hidden wires etc!!! In addition don’t do what I did when drilling. See the photo for how the chuck damaged my pod as I drilled.
(Completed install of the A pillar pod mount)
(A close up of the A pillar pod mount)
(“The Scratch” This is also a good opportunity to see how the o ring finished off the mod)
(Completed install of the in dash mount)
When finished drilling check for clearance and drill a larger hole if necessary. I used a pressure fit hold for my LED so I didn’t have to use the nut and washer provided with the kit. This worked very well for me and the threads have quite a grip on the pod. The o ring took up all possible gaps between the LED and the pod.
2 – Run the hot wire (generally red) to the GPR relay under the hood. This is located in the center of the valley. Be sure to run enough wire.
3 – Run the ground wire (generally black) to the ground for your gauges, dash, etc. This is located just behind the fuse panel cover on the right. Be sure to run enough wire.
4 – Trim wires that will be attached to LED to length.
5 – EASILY FORGOTTEN – Run the red and black wires through the mounting hole AND the o ring.
6 - Use a red butt connector to join the red wire to the red lead on the LED. Use another red butt connector to join the black wire to the black lead on the LED.
(Butt connectors joined and in place)
(Closeup of butt connectors joined and in place)
7 – Adjust your black wire and attach as necessary.
Don’t pull too hard and rip the wires out of the butt connector on the LED end!!! Cut the wire to length when satisfied and attach the small red ring terminal (Mine was blue)
8 – Remove the 5/16” bolt and place ring terminal on bolt. Reinstall.
(Wire cut, terminal connected, and installed. See Arrow)
9 – Attach the large red ring terminal to one end of the fuse holder. I chose the female end, but it doesn’t matter.
10 – Remove the ½” nut off the GPR and place the ring terminal on the connection. This should be the last ring terminal before the nut. (The highest in the stack) Retighten connection.
(Fuse installed. See arrow)
11 - Adjust your red wire and attach as necessary. I attached mine to the wire hider where the hood meets the cowl. Don’t pull too hard and rip the wires out of the butt connector on the LED end!!! Cut the wire to length when satisfied and attach the final red butt connector joining the fuse holder and the red wire.
12 – Do a final check for fitment and completion and install the fuse.
13 – Try it out! Hopefully your first try goes better than mine ; )
__________________
Scott
01 F-250 Ext Cab, Short Box 7.3l PSD
Silverline 4" SS, 6637, DP-Tuner (NS,S,40T,40D,60T,80E,120R), JWVB, OBA, In Tanks, CCV, De-Foiled
GPR LED, fog/high beam mod, Banks A-Pillar Gauges, Bilstein's, 08 Gate_________________________
  #2 (permalink)
Old 04-02-2008, 02:24 PM
sflem849's Avatar
They only allow three attatchments per post so the parts and tools are above and the three directions pages are found in this one.
__________________
Scott
  #3 (permalink)
Old 04-02-2008, 02:36 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
Nice write-up. I want to do this one myself, just haven't gotten around to it yet. Reps to you.
Edit: I have to spread it around first.
__________________
Jeffrey
2011 Ford F-150 Lariat Ecoboost
2004 Ford F-350 Lariat 6.0 (New Project)
  #4 (permalink)
Old 04-02-2008, 02:55 PM
dryfly dryfly is offline
dryfly is gaining momentum as a positive member of FTE.dryfly is gaining momentum as a positive member of FTE.
Great job on the write up.Rep points given.
  #5 (permalink)
Old 04-02-2008, 03:11 PM
DieselCamper01's Avatar
DieselCamper01 DieselCamper01 is offline
2001 Ford F-350
DieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to behold
That is the exact spot I put mine! Great write up. Reps
__________________
Jay
Need more Cowbell
2001 F350 Lariat CC LB 4X4, Various mods
http://www.roadsidehelpnetwork.org/
  #6 (permalink)
Old 04-02-2008, 06:11 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Outstanding write up esp. with the pics!!! Reps given
__________________
Jim
01 F350 DRW, Autometer Gauges, Custom CAI with Petes Cover, 6" Miter Stacks, 38R Turbo, Casserly SS Injectors, Live tuned by DP-Tuner (F6) , and a bunch of other stuff some show, and some go. PAA #14
RIP Mark.. I'll never forget you!!
  #7 (permalink)
Old 04-02-2008, 06:58 PM
KelVarnson KelVarnson is offline
KelVarnson has a great reputation on FTE.KelVarnson has a great reputation on FTE.KelVarnson has a great reputation on FTE.KelVarnson has a great reputation on FTE.KelVarnson has a great reputation on FTE.
Excellent writeup, thanks for puting in all of the effort. Rep points given.
I only have one suggestion:
You don't need anywhere near 18 gauge wire, regardless of length. If I were doing this job, I would use 24 or 22. Electrically, you could actually go much smaller, but it gets to be hard to handle and to find connectors for. 22 gauge butt splices and terminals are abundant.
__________________
'02 F250 SCLB 7.3 4WD, 130k. 6637 Filter, JW Valve Body, 6.0 Trans Cooler, Moog Ball Joints, 285/75 16 Michelin LTX-AT2's, Line-X, Snug-Top Shell, Yakima Racks.
  #8 (permalink)
Old 04-02-2008, 08:31 PM
RussB's Avatar
RussB RussB is offline
RussB is gaining momentum as a positive member of FTE.RussB is gaining momentum as a positive member of FTE.
Thats is a great write up... Good pics and everything.. I'd give you reps... but I have no idea how to do so.......lol !!!! Also I've tried today to find the LED @ a few places. Our Radio Shacks here in Canada have been bought out by a place called "SOURCE" They have alot of the radio shack stuff but not this LED... nor can they get it for some reason... I want to do this mod, but have no idea how to get ahold of the right part... Can some one get an extra LED and mail it to me ???? Is there anyone that has an extra one.. ???
Thanks guys !
__________________
Russ PAA# 25
03, 350 Lariet, NEW OEM MOTOR ! 315 Toyo M/T's, 9000lb Warn, Man. Hubs,4-light force 170's, Warn hubs, 6637/Pete's cover, CCV, Gauges, 4" Lift, 4" TB, GPR LED, SS HPX, RR FRX, DP F6, RR OCR, RR Plenum inserts, F650 dash, Aeroforce Scangauge, Stage 1's, 6.0L IC/TC, and 38R
  #9 (permalink)
Old 04-02-2008, 08:38 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke robinsonpowerstroke is offline
2000 Ford F-250
robinsonpowerstroke is gaining momentum as a positive member of FTE.
Nice write up. One question, what is the idea of having a GRP LED? Any advantages to having it?
__________________
Justin---2000 F-250 7.3 PSD
3 Autometer Carbon Fiber Gauges, 4" Block Lift, DP Tuned, 16x9 Moto Metal Rims, 315x75-R16 Cooper Discover AT3s, Warn Manual Locking Hubs, 5" MBRP w/Delete Pipe, 6637 w/Pete's Bag, Wicked Wheel, CCV Mod, Foil Door Locks, GPR LED, Shift Kit w/Kolene Steels & Red Frictions, In-Tank Mods, Foil Delete
  #10 (permalink)
Old 04-02-2008, 09:26 PM
sgrol sgrol is offline
sgrol is gaining momentum as a positive member of FTE.
Quote:
Believe it adds an extra 10 HP!
__________________
Steve
2000 F 250 7.3 Powerstroke, 4x4, CC, AFE Stage II, MBRP 4" turbo back, 6 Pos DI Chip, IAH delete, Guages, CCV Mod, A.E., Tru-Cool, Vacuum Htr bypass, HPX, EBPV gut, IH Uppipes, Reg fuel return, Van Turbo
  #11 (permalink)
Old 04-02-2008, 11:05 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
It is a positive indication that the glow plug relay (GPR) is actually putting out current to heat the GP's.
The mere lighting of the "Wait-to-Start" light is no indication that the GPR is actually any good (and it's a fairly high-failure item).
It's not so important to those that live in mild climates, but absolutely necessary to those that live where it gets COLD.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks, and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, spin-on hydraulic filter, coolant filter, 6637 & cover, bypass lube oil filter, HPX, Hutch n' harpoon.
Email SpringerPop SpringerPop's F-350
  #12 (permalink)
Old 04-03-2008, 12:24 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1996 Ford F-350
My Garage
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I might stop at Radio Shack tomorrow, pick up an LED, and modify my gauge pod for the LED before I paint it. I never figured it was very necessary, but now I can see how it would be helpful to have.
__________________
Chase
PAA Member #2
97 F350 CCLB 4x4 PSD
96 F350 CCLB 4x4 PSD - totaled 4/17/11 and sorely missed
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / Back Country Rebels / SAWS / BRC
  #13 (permalink)
Old 04-03-2008, 12:46 AM
RussB's Avatar
Quote:
Chase..... If you don't mind.... Pick me one up to... I posted a explanation above, but I can't get the little buggers up here... I'll send ya my address and the million dollars it will cost you, if you don't mind doing that for me... Let me know if you can help !! Thanks Russ
__________________
Russ PAA# 25
  #14 (permalink)
Old 04-03-2008, 08:56 AM
sflem849's Avatar
Reps to all of you!
Kel, you know the deal. Half the reason I said 18 is bc the 20 and 22 are just a PITA to work with. I would have to speculate I pulled the conductor apart or something like that when I installed it the first time. I ohmed the little wire and it jumped from about 5 to 50 and back and forth. It was either my crappy DMM or crappy wire. It could also have been the lack of ability to find the proper connectors and doubling the conductor up in the connector.
RussB, how much does it usually cost to mail something to Canada? The part weighs next to nothing.
If you have any pictures of other mounting locations add them to the thread! That way the guys who haven't done the mod yet can see all the possibilities that have already been explored.
Thanks again!
__________________
Scott
  #15 (permalink)
Old 04-03-2008, 09:30 AM
1996 Ford F-350
My Garage
Quote:
I'll see if I can scare any up at the local Radio Shack today, if not I will be in a bigger town next week and can probably find some. Any color preference?
__________________
Chase
PAA Member #2
Tags
12, 2760272, 73, ais, box, drill, f250, ford, glow, gpr, grp, led, mod, plug, powerstroke, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
