Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-01-2008, 07:05 PM
ALEXVB22's Avatar
ALEXVB22 is starting off with a positive reputation.
Blend door actuators gone Bad In my truck?
Hi,
My name is Alex and I'm new to the forum...
I have an 05' kingranch f-350 dually, crew... the works basically.
Any how, just recently I think my blend door actuator went up or broke or something.... not sure, thats Y i'm here, lol. The air is stuck on blowing out of the top vents (on the window, defrost). I have a digital (so I guess thats automatic) control system and when I push any of the buttons to change the vents... well nothing happens...
So my question is what do you think it could be? and How should I go about fixing the problem?
Thanks alot,
Alex
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-03-2008, 02:59 PM
ALEXVB22's Avatar
So I have done a lot of reading through the threads and still can't quite figure out my problem.
The system is stuck on Defrost... and I do remember having an issue with my 4 wheel drive last week when I tried to turn it on from inside the cab... wasn't catching for some reason so I had to do it manually.
From what I'm reading and please correct me if I'm wrong... is that it's earthier a vacuum hose/ problem or the Blend air door.
I'm leaning toward's the Vacuum hose/ pump? problem because of the 4 wheel drive issue I had. ( I read that your 4 wheel dive selector changes the truck into 4 wheel mode via Vacuum tubes.... I checked those tubes that are attached to the wheel to see if one had slipped off but it didn't look like it did.. would suspect it because I don't go off road often.
I also read that I should be looking for a "hose tree" near the top of the fire wall??? I can not locate it, lol and I have no clue what I'm looking at.
So, Please any help would be greatly appreciated,
Alex
  #3 (permalink)
Old 04-03-2008, 03:35 PM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
You probably lost a vacuum line. Both the climate control air flow direction motors and your front hubs operate with vacuum.
The schematic of the truck's vacuum system should be on the emissions label under your hood.
If your vehicle is a diesel (you didn't say), it has a vacuum pump under the hood that supplies these auxillary systems.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 04-03-2008, 04:15 PM
ALEXVB22's Avatar
o, sorry.. it is a diesel...
Thanks for the info.. I'm head outside to take a look right now..
Alex
  #5 (permalink)
Old 04-03-2008, 09:54 PM
ALEXVB22's Avatar
Ok,
Found the problem.. it was a vac hose!... lol
A chip munk or something got in under my hood and chewed through a few things. The hose being the one he got al the way through...
Don't think he could still be in there after all that driving do you? Been two weeks now since it first started..
Alex
  #6 (permalink)
Old 04-14-2008, 03:05 AM
orng1's Avatar
orng1 is starting off with a positive reputation.
I'm having this same issue, only air coming from the defrost vents. Where did you find that loose vac line? I'm going to have to go search for it tomorrow.
  #7 (permalink)
Old 04-14-2008, 08:02 PM
ALEXVB22's Avatar
I found the vac. hose on the passenger side. behind the battery. They are about 1/8th in. thick and are made of hard plastic. I just went to autozone and they gave me a 1ft. line that I just slipped right over top of the broken ends. Fixed it perfectly.
Good luck...
Alex
Ps. I have some pics. I just have to get them off my camera cuz I do want to post them so others w/ the same problem can fix it w/o out paying an arm and a leg.
  #8 (permalink)
Old 04-14-2008, 11:45 PM
orng1's Avatar
Thanks now I just need a free chance to look for it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
