look's good,i don't know about ufm? anthing about tbn or sae? what oil are you using?
kurt
__________________
Kurt
'96 f250 h.d. p.s.d. super cab,long bed,e40d built by john wood.gutted ebpv,3x4 d.p. & 4" exhaust,gauges,ab injectors,tranny& inter coolers,ex. brake,ccv mod,130 gallons motion lotion,fs2500 by pass,certified j b welder
I compared my last report from Blackstone to yours. I was running Rotella T 15-40 and mine ran fairly close to yours. You did have about 700 more miles on the oil than I did. In my opinion Caterpillar didn't seem to be as through as Blackstone.
I think you mentioned that Blackstone is also doing an analysis on your oil, hopefully it will be from the same oil change, if it is then you will really have a basis for comparison.
Let us know how the two compare, I for one will be very interested.
Rog
__________________ 1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-6 Pos.PHP Chip-140V IDM
The "Cure"-1.0 Turbo-Detroit Locker.
Cadillac Battery Water.
1998 Black Ranger 4X4 4.0 Auto. 102K miles.
I know that Caterpillar does not do as good a job as Blackstone does. Just a little cheaper and I wanted to get a analysis back quickly. Also then I can do a comparison of CAT and Blackstone.
Ordered the Blackstone kit a while back, should be here the end of this week.
I saved about 500 mL from the same oil change so that I can do a comparison.
Those numbers look pretty good. iron is a little higher than Blackstones averages for the PSD but nothing to be concerned about. My Iron is higher than yours even
here is all the samples I have taken on my truck
__________________ Tim
1997 F-350 CC 4x4 PSD Auto 260K
Tim
2/5/07 225K.
That has to be when you lost the turbo?
I had about the same iron spike. I rebuilt the turbo then all was good on the next stone report.
2/5/07 225K.
Bill
yep thats the one!! I was expecting worse so I was a little relieved when it came back like that. The AL was the base plate and the FE was the thrust bearing grinding away. Hoping the Schaeffers helps my higher than average FE trend.
My Alum was good. Base plate fine. Had a spike in copper with the iron.
Iron-83 and copper-152. Yikes!!! 12K on oil.
Had to be turbo shaft and bearings. All though to the eye/feel all was good.
With Blackstone if you already have the sample kit it takes about 5 days after I sent them out to get the report via email. I think going "postal" it only take my samples 2 days to get there so that will vary.
