7.3 and bio diesel - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
7.3 and bio diesel
Old 04-01-2008, 02:16 PM
fphilli11 fphilli11 is offline
fphilli11 is starting off with a positive reputation.
7.3 and bio diesel
Has anyone out there been burning the BP bio diesel in a 1999 or newer 7.3? I would like to try and have got some good respones from the other forums and just wanted to know if anyone in Michigan has tried it either partial or full tanks with out issues. I understand that bio does attack rubber fule hoses, but have been told the 7.3's built in the 90's to current do not have any. Please advise, thanks.
Old 04-01-2008, 04:29 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is online now
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
I have been using B5 to B20 in all my vehicles for about 7 years with no ill effects. I get my fuel from Crystal Flash Energy -Lowell, Mi. I use a premium fuel and they use soy B100 as their feedstock. I would ask where they get their bio from. You will have to change fuel filters after about 3 tanks of bio as this will clean out your tank. Go to National Biodiesel Board - www.biodiesel.org - www.nbb.org for more info on biodiesel.
Old 04-01-2008, 10:44 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Bio will be fine in your truck.
But you'll have to clean the filter, or change it for sure.
It doesn't eat lines up as bad as they say.
If you have old weak lines, they will probably caus problems, but a powerstroke should be fine.
Tim1 runs bio without issues.
Old 04-02-2008, 09:06 AM
Thanks
Thanks to all, I will give it a try.
BP Bio Diesel jack_pine 6.7L Power Stroke Diesel 36 05-31-2012 09:06 AM
bio diesel in the 7.3 idi issues? halaferd Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 10-03-2011 01:53 AM
Need help wit bio diesel 93idi7.3 Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 03-15-2011 09:31 AM
6.0 bio diesel bcfordguy Bio-diesel, Propane & Alternative Diesel Engine Fuels 6 02-19-2008 08:00 PM
Bio-friendly hoses? woogs Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 12-14-2005 12:35 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1999, 73, b100, bio, biodiesel, diesel, ford, litre, problems, tanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
