Oil Leaks Common?
Oil Leaks Common?
I'm considering purchasing a low mileage (~25k) 6.0 powerstroke. I'm mainly looking for something that is well within warranty period. I was recently informed (by another thread) that the 5yr/100,000mi powertrain warranty is only for major parts and would not cover something like an oil leak. Speaking of oil leaks, I've been doing a lot of reading on this forum about oil leaks and they appear to be very common.
My question is:
1) Are oil leaks common? I mean can I just expect to have a few before the truck reaches 100k miles?
2) Is it worth spending the extra $$$ on something with with only 1 yr left on the warranty, or should I spend $10,000 less on something of the same year with maybe 100k miles. There area lots of mint condition King Ranch's out there. I guess I'm not interested in spending the money if the warranty does not come with it.
Thanks for your help and advice.
My question is:
Im pretty sure oil leaks are covered under the 5yr 100k diesel motor warrenty. After 36k or 3 yrs you have to pay a $100 deductible. A little heads up, the powertrain warrenty (tranny and drive train parts) on 6.0L trucks up to a certain month in 06 (I think it is June) got bumped to 5yr-60k. Before that is was 3yr-36k
There is a post on here about the most common oil leaks in the PSD, you might research that. Only problem is that it won't go into "how often", that I am not sure of. For mine, I have had 3 rear mains go, and an ICP sensor that was leaking and repaired, all under warranty (70k miles). You can purchase extended warranties to 200k miles, I am looking into that now, as my extended warranty to 75k miles is up soon.
Good luck
Good luck
