You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thanks Ill take a look into that although I had A similar issue with the first batch but it was real clear in the mixing bottle but got slightly cloudy when I washed it.
I am thinking about running it through another heat cycle any thoughts ?
By the way the picture its small 34K I took it with the camera phone
New oil will not have "black" colored glycerol, since it hasn't been "burned" by cooking yet. The "haze" will disappear once the bio is "washed". Looks like you made a good test batch!!
Try increasing the temp to about 140 deg also.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Is there a clothe that can serve as a strainer to help eliminate fat bleed through in the dregs? Something like a toilet paper roll oil filter? (replaceable)
__________________
Think outside of the box - especially if you built it yourself
Ordinarily the solid fats are on the bottom. That puzzles me. What you have there is above the clear fluid.
I wonder if an aerator could be used to tumble the mixture prior to the settling out stage?
Skimming is unnecessary Dutch. He stated that he used "new" oil. Oil which hasn't been used will have no solids to filter out.
Aerating the freshly mixed bio BEFORE the settling phase would just keep the glycerol suspended, and promote an emulsion.
__________________
