Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-01-2008, 10:38 AM
mustang81 is starting off with a positive reputation.
arp bolts
I rebuild a 1977 400 and want to know if i have to get arp bolt on connecting and main. At least i was going to buy connecting rod bolts, they look small to hold 4" bore and stroke or i can use stock rod bolt ?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-01-2008, 10:44 AM
beartracks's Avatar
beartracks is starting off with a positive reputation.
Most people will replace at least the rod bolts anyway. Might as well get the ARPs if budget isn't real tight. Much stronger than stock.
__________________
Bear Tracks
1977 F-100 Ranger XLT,400,C6,GV
Mod's Listed in Gallery
Click Here To Help Support FTE
  #3 (permalink)
Old 04-01-2008, 10:51 AM
Have you seen the stock one broke ? Just mild rebuilt 1500-5500 rpm
  #4 (permalink)
Old 04-01-2008, 11:43 AM
hollenjoe is starting off with a positive reputation.
Ive never seen one break before but it is highly recomended to change them cuz these engines were never ment to rev more than 4k and the obvios wear due to milliage, its pretty easy and they are cheap. I changed them myself i dont know why people say theres some adapting to do its pretty plug and play, they just have to be pressed out and in, I noticed they have a redish color to them, i guess its due to the hardness degree of the bolt.... I left my original mains though....
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
  #5 (permalink)
Old 04-01-2008, 12:05 PM
The stock rod bolts are all ready torque but it's not a big deal my oil pan is not on yet. I have a good torque wrench.
  #6 (permalink)
Old 04-01-2008, 02:06 PM
acct21 is starting off with a positive reputation.
Are you asking advice? You've replied cautiously to each posted recommendation.
The responses have been pretty unequivocal. If you're still not convinced, button up the oil pan and off you go.
  #7 (permalink)
Old 04-01-2008, 02:24 PM
beartracks's Avatar
Once the bolts have been in the rods and the rods are "reconditioned" you can't just take them out and replace them. They will have to be straightened again.
__________________
Bear Tracks
  #8 (permalink)
Old 04-01-2008, 03:15 PM
The rod are not bent, to my knowledge. Why ? same torque ? Can you explain ?
  #9 (permalink)
Old 04-01-2008, 06:38 PM
Quote:
I spoke to my machine shop about it, and it depends on the way you are removing them and replacing them, there they use a machine simiar to the one removing piston pins... and ofcorse you cant change your bolts the way mustang 81 wants to do it, you will have to remove your pistons from the block other wise you could hurt your rods by forcing them out and in.....
__________________
  #10 (permalink)
Old 04-01-2008, 11:56 PM
mark a.'s Avatar
mark a. is gaining momentum as a positive member of FTE.mark a. is gaining momentum as a positive member of FTE.
How you remove and install rod bolts would have nothing to do with distortion of a rod bore. The ARP rod bolt will distort the rod bore because they are a little bigger (fatter) and take more to torque than a stock rod bolt, hence the distortion they WILL produce. It says right in ARP directions that you can't just put them in and run them.
__________________
'79 F250 13" lift 42" Super Swampers
  #11 (permalink)
Old 04-02-2008, 12:04 AM
hmmm thats wierd i compared the ones i had earlier and arp ones and they were identical except for the "arp" amrk in the head and the redish color, and went right in smoothly...
__________________
  #12 (permalink)
Old 04-02-2008, 12:47 AM
mark a.'s Avatar
Quote:
Used set of ARP's measured at the knurl .3785. Stock bolt measured at knurl .3780 = .0005. The actual over all diameter of the ARP bolt is .002 bigger than stock.
__________________
  #13 (permalink)
Old 04-02-2008, 08:12 AM
I'm gonna change them my way anyway. I know how to remove them without hit because i remove 2 of them from my 351m. I'm a welder and i know how to make something to remove them, work like a press. I made my own puller to remove the damper, piston stop to find the topdc. .002 ,i thing is not enough to tight my clearance between my connecting rod.
  #14 (permalink)
Old 04-02-2008, 08:29 AM
probably smaller due to the stress.
  #15 (permalink)
Old 04-02-2008, 12:00 PM
Mark is right, iv heard that everywhere, the reason still stands, what could happen if you just change them, i didn´t see any issues they just went out and the new ones in, the cap of the rod went in smoothly and torqued the bolts in without any trouble, balanced the engine, everything very smooth.... so whats the deal? what is the wrong here, consequences?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
