How much is my 302 worth. - Ford Truck Enthusiasts Forums
Old 09-10-2002, 10:20 PM
prodigy prodigy is offline
prodigy is starting off with a positive reputation.
Post How much is my 302 worth.
Yes. I recently bought a 82 Econoline. It has good motor and transmission and rearend, ETC. Just the title was messed up. So i got the whole van for, get this $75.00. I bought it for the transmission mostly. Well now i am stuck with this 302 that runs fine and if the odometer is correct, only has about 70xxx miles. It looks like it has a fairly new carbearater. It has a two barral intake and carb. I was wondering about how much 302 run. About how much should i ask or get out of my 302. thanks
Old 09-10-2002, 11:40 PM
JTY JTY is offline
JTY is starting off with a positive reputation.
I'd say it depends, complete engine or not? If it's with the accessories, I'd say around $500.
Old 09-11-2002, 11:56 PM
Ford Truck Racer Ford Truck Racer is offline
Ford Truck Racer is starting off with a positive reputation.
Around where I live a block is around 250. Do a compression check and if you know it don't need rebuilt I would agree that its worth at least 500.
Old 09-15-2002, 05:00 PM
Quantrex Quantrex is offline
Quantrex is starting off with a positive reputation.
$250 for a used 302/5.0L block? Wow.
Old 09-15-2002, 09:45 PM
ryanguglich ryanguglich is offline
ryanguglich is starting off with a positive reputation.
302 or 351? belchfire 1987 - 1996 F150 & Larger F-Series Trucks 2 11-02-2013 02:40 PM
How many rpm's? CDF302v8 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 42 11-16-2008 01:12 PM
292 to 302 swap MinnesotaJeff 1961 - 1966 F-100 & Larger F-Series Trucks 2 06-01-2004 09:32 PM
94 302 plowboy2155 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 09-12-2003 11:29 PM
aod on a '78 302 motorhead 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-04-2001 04:26 PM
Tags
1957, 1986, 302, 302ci, 50, 91, c4, engine, f150, ford, motor, series, v8, werth, windsor, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
