Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-01-2008, 12:07 AM
ford montana is starting off with a positive reputation.
bunch of questions from a noob
OK fellas, I'm new to diesels so here are the my questions. firstly my truck is a 2000 CC 4x4 7.3 srw . things i think that were done to it before i got it. i think the exhaust was done appears not to have a muffler and is about four inches around, k&n type air cleaner, and it looks to be leveled i don't think lifted and 35inch tires. i bought gauges but haven't installed them yet. when i install them what kind of temps should i watch out for,on the trans and exhaust and what does the boost gauge warn me about. i don't do alot of towing yet but hope to find a toy hauler 5er soon. i get the max towing weights but how much king pin weight can i handle. i am from montana very hilly terrain if that makes a difference. thanx for your help
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-01-2008, 01:26 PM
miller_feed's Avatar
Hook it, I'll pull it.
miller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to behold
Welcome to FTE,
Look at the down pipe coming off the turbo, if it is 4", you have a after market exhaust. Next, Get rid of the K&N filter, look in the 7.3 fourm and do a search for the 6637 filter. Way better for our Diesels.
On the trans temp, don't let it get over 210* 220*, try to keep it under 200*. You will not see that high of temp not towing.
EGT, keep that under 1250*, again you should not see that unless towing. Sometimes with a tuned engine at WOT, you can get close.
Boost, I can make 30+ # boost with what I have on my truck. Our turbo does not like over 25# boost. The boost guage could let you know if you get a lead in one of your IC boots.
Come visit us in the 7.3 fourm, many great people and loads of info.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's filter cover, BTS-VB, DP-TUNER- stock, 40t, 60t, 80e, 140s, HI, OBA, 203*, billet housing, IH bolts, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler. For now.
Jim, Roland, Will, JD? I want to go somewhere.
  #3 (permalink)
Old 04-01-2008, 01:43 PM
stormyrider is starting off with a positive reputation.
Also, use your gauges to monitor exhaust temp when you reach your destination. Do Not shut down your engine until it has idled enough to get the exhaust temps down to around 300 degrees, this will make the turbo last a lot longer. If you shutdown hot it can boil the oil out of the turbo bearings leaving solids behind which really shorten the turbo bearing life.
K&N filter is not something I would use on a diesel, lets too much dirt through. I like the AIS filter setup as it is a ford factory approved change and a big improvement over stock. Mated with a air hole in the bulkhead it draws in cooler outside air which should help the horsepower and your map sensor is still in the airstream.
__________________
2000 F250 4 x 4 77,000 miles conventional cab longbed
six speed manual transmission.
AIS intake, 4" turbo back Magnaflow S/S exhaust
inlet & outlet pyrometers & boost gauge
  #4 (permalink)
Old 04-01-2008, 05:51 PM
Thanx
Thanx for the help
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
