Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 03-31-2008, 10:44 PM
camodown's Avatar
camodown camodown is offline
Garage is empty, add now
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
How to replace your power steering pump...
I just got done replacing my powersteering pump on my 2002 7.3 and figured someone may benefit from pictures and a written how to...
Disclaimer: Ford-trucks and I are not responsible for anything which can result from mis installation or other issues that may arise from following this tutorial.
With that said, you will need a 1/2" drive torque wrench capable of 60 lb-ft, an 11/16" socket, a 3/8 to 1/2" drive socket adapter, a 7/16" socket with extension, a power steering pulley remover and installer kit, 1 qt Type F Ford transmission/power steering fluid, a 5/8" open end wrench, a new teflon seal for the high pressure line, a crescent wrench, adjustable wrench for removing clips, a flat bladed screwdriver, a drain pan with rags, and of course a motorcraft or equivalent power steering pump.
First remove the air cleaner hose from the main housing using a flat bladed screwdriver. Set aside.
Click the image to open in full size.
Then, loosen the 7/16" spring clamps for the intercooler boots, you do not need to remove them completely. Set the pipe aside. CAUTION: be careful when removing the intercooler pipe as the always hot feed to the alternator is near where you will be removing the pipe.
Put your 1/2" square drive in the tensioner adjuster hole, and loosen the belt off the powersteering pump pulley.
Next, use your adjustable wrench and remove the overflow hose by clamping down on the two tangs on the spring clamp. You will use the same procedure
on the lower feed line on the pump's bottom.
Now, remove the high pressure line from the pump, positioning your drain pan below pitman arm as fluid will start to drain out.
Since you broke the teflon seal while removing the high pressure line, install a new seal by either working the seal by hand slowly and carefully expanding it with your fingers, or by using the special Ford teflon seal installer. I worked it on by hand and have no problems.
You should now get your pulley puller ready to work. Following are pictures of how to remove the pulley...
It takes quite a few cranks to get the pulley assembly off, but make sure that you always have your hand under the pulley as if it fell, the pulley could get damaged.
Now remove the three main bolts holding the pump to the bracket. These are 11/16" bolts and are pretty snug.
Once those three bolts are taken out, you can remove the lower clamp and hose from the old pump, and transfer it all to the new pump.
Position the new pump where to old one was, making sure you put the return line, high pressure line, and drain hoses on. Tighten the three bolts back in. Ford spec was 60lb-ft for the three large bolts, however, mine were really snug at 45lb-ft. Take it as you please.
Now you can install the pulley. Make sure you drive it on straight. Using the tool, thread the inner bolt all the way into the pulley until it bottoms out, so you have as much threads in the shaft as possible. Now, just crank the installer down until it stops going. This will align the shaft perfectly flush with the pulley face. Click the image to open in full size.
You can now reapply tension and route the belt how it was originally. Fill the reservoir on the pump with your Type F fluid. Start the truck and apply the brakes while steering lock to lock, paying attention not to hold the wheel at lock for too long. Do this a few times, then shut the truck off. Check the fluid level and top off accordingly.
That should be it. Have fun!
  #2 (permalink)
Old 04-01-2008, 06:49 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Great write up. I love pictures. Folks like you are what makes this site so great. Rep points sent.
Welcome to FTE.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 440,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #3 (permalink)
Old 04-01-2008, 07:20 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Great write up!! Reps given...
The only other tip I have is that you can put in syn ATF and keep those noisy Ford pumps quiet. I flushed mine with Mobil1 Syn ATF and it really quieted it down. Steering seems to be smoother, too.
EDIT: And oh yeah -- see all that oil on the blue IC tube boot? Do the CCV mod to keep it clean.
__________________
  #4 (permalink)
Old 04-01-2008, 08:18 AM
sflem849's Avatar
sflem849 sflem849 is offline
sflem849 has a good reputation on FTE.sflem849 has a good reputation on FTE.
Nice writeup. These pumps must not be the greatest as mine went out at 95,000 miles. I had it done for $100 and I think I may have them put my new one in. They must not have flushed it well or the hoses must be coming apart taking out pumps, bc I have to put a new one on. (115,000)
__________________
Scott
01 F-250 Ext Cab, Short Box 7.3l PSD
Silverline 4" SS, 6637, DP-Tuner (NS,S,40T,40D,60T,80E,120R), JWVB, OBA, In Tanks, CCV, De-Foiled
GPR LED, fog/high beam mod, Banks A-Pillar Gauges, Bilstein's, 08 Gate_________________________
  #5 (permalink)
Old 04-01-2008, 12:25 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Wink
I haven't checked my '99s owners manual yet, but is it true that we should use the old fashioned Ford type "F" fluid in the p/s??
I have heard of several people on here that have flushed out the p/s and added synthetic Mercon (mercon V) fluid???
__________________
Support FTE
  #6 (permalink)
Old 04-01-2008, 12:31 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
Very nice writeup. Pictures are always helpful. Reps sent.
__________________
Jeffrey
2011 Ford F-150 Lariat Ecoboost
2004 Ford F-350 Lariat 6.0 (New Project)
  #7 (permalink)
Old 04-01-2008, 01:35 PM
powerstroke1869's Avatar
powerstroke1869 powerstroke1869 is offline
powerstroke1869 is starting off with a positive reputation.
great post and always beneficial to have pictures as well.. i was thinkin the same thing as joe.. seeing all that oil on your i/c boot not good. another mod on the way i think
__________________
Bobby
O1 SD CC 4X4
Mods: 6637,4" MBRP turbo back exhaust, 285/75 bridgestone dueler revos, Zoodad,foil removal,autometer gauges, DP Tuner stock, 80 econo, 120 race ,OBA, CCV mod,wicked wheel,gpr LED,HPX,203*thermostat w/ billet housing,fumoto drain,blank pedistal, ATS housing
  #8 (permalink)
Old 04-01-2008, 07:13 PM
camodown's Avatar
Thanks for the nice welcomes...
I always think pictures help a lot rather than trying to explain a fix with words, glad ya'll liked it.
I need to do the CCV mod also, I've been reading up on it, just haven't had time to do the mod itself. I'll be doing a rear hub seal replacement here soon and will do a how to of that also if anyone is interested, just need to find time.
Oh, I should have done synthetic but ended picking up some type F; it was priced decent...
Thanks again for the welcomes!
p.s. What are the rep points?
  #9 (permalink)
Old 04-01-2008, 07:39 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
Nice post. Click on the user CP on the blue bar above the thread. It is how folks get positive and negative comments. After you get 100 you will get a new green rep box.
__________________
Mike
2001 Auto Crew Cab 4X4. 38R and Swamps Hybrids. Transgo and diode Tranny. 400HP but not really. 05 front end and stickers makes it faster.
  #10 (permalink)
Old 04-01-2008, 10:01 PM
camodown's Avatar
I see... thats cool. Thanks for the comments and rep points!
  #11 (permalink)
Old 04-01-2008, 10:11 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Welcome to FTE! Excellent job on your pics and description definate reps given.
__________________
Jim
01 F350 DRW, Autometer Gauges, Custom CAI with Petes Cover, 6" Miter Stacks, 38R Turbo, Casserly SS Injectors, Live tuned by DP-Tuner (F6) , and a bunch of other stuff some show, and some go. PAA #14
www.roadsidehelpnetwork.org
RIP Robin Gone but not forgotten....RIP Mark.. I'll never forget you!!
  #12 (permalink)
Old 03-12-2010, 11:00 PM
Drenalin Drenalin is offline
Drenalin is starting off with a positive reputation.
camo......any chance you still have these pics? Seems the hosting site has deleted them...thanks
  #13 (permalink)
Old 03-12-2010, 11:59 PM
phatf250's Avatar
phatf250 phatf250 is offline
phatf250 is starting off with a positive reputation.
nice post. i just did mine and the steering gear box as well. not to hyjack the thread but i have 35/15's on and i still cant turn the wheels at a stop, is this normal
  #14 (permalink)
Old 03-13-2010, 09:38 AM
SGnAZ's Avatar
SGnAZ SGnAZ is offline
SGnAZ has a good reputation on FTE.SGnAZ has a good reputation on FTE.SGnAZ has a good reputation on FTE.
Quote:
I'm also
__________________
Steve
2000 F-250 XLT 7.3L 4x4 LB
  #15 (permalink)
Old 03-13-2010, 01:13 PM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
It looks like he organized(categorized) his album and the links changed..
Nice job.. Good post. Takes time to take all the pictures and post stuff like this for us to see . Thanks millions. Good info
All can be seen here. Power steering pictures pictures by camodown1 - Photobucket
Tags
73, 73l, check, diesel, f150, f250, fluid, ford, liter, power, pump, removing, replacing, seal, steering, teflon, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
